With what diagonals?What about using the stock front spreader bars and adding to them? Doing that would keep stock integrity and add A pillar through dash with bars running above and below windshield.
That would be the limiting factor. Hard to package that without helmets and harnesses?With what diagonals?
You are starting to catch on.That would be the limiting factor. Hard to package that without helmets and harnesses?
Appreciate it.Go back to the part about diagonals creating triangles. There are none, that should not be true.
Not that you will be able to copy it, but look at pictures of offroad race cages for ideas on what they do with diagonals and why they use them to create nodes. We won't ever get there but even a few is far better than depending on just the resistance to bending that straight tubes have.Appreciate it.
When going through the dash was there anything in the way once a hole was cut in the dash itself? Or was it a straight shot through?Yes it is. Around late December, early January.
@toximus are your A pillar bars 2 piece? Ifso, why?
