I have a 2004 that makes a squealing sound between 15 to 25 mph. It seems the sound happens inly when throttle is applied. My assumption is bad u joints, so I plan to replace the axle and rear drive shaft u joints. Any other possible causes?
Also, although the brakes pads look healthy, im going to take them apart to see if the issue is in the brakes. I do have some squealing coming from brakes upon initial pressure.
Please let me known if you have any insights.
