Steering components: OEM vs aftermarket?
imactj2004
Bay Area
Feel free to point me to a post that answers this decision process. Didnt immediately find it in the “official” lift thread.
When should someone go with aftermarket steering components vs OEM? ie: beyond a certain lift hight? type of use? if replacing X then also replace Y?
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
The tie rod is the weakest part of the steering system, it is made from a thin hollow tube. Most upgrade their tie-rod to something stronger soon after they start offroading. The OEM tie rod can bend if you get into a bind offroad or run it into anything. So if you're planning to go offroad much I'd have a stronger replacement tie rod on my short list. What size tires are you running and do you plan to go larger later?
imactj2004
imactj2004
Bay Area
I’m only on 31” with a 2” lift. May go down to 29” tires since Im not really planning any serious off-roading. Just the occasional trail use. Trying to get what was a salvaged vehicle back into good shape for my teenage driver to use as a daily driver.
Current steering components have some play/shimmy so Im trying to determine whether to simply replace bushings or actual hardware.
Jerry Bransford
TJ Guru Moderator
Staff Member
Here's a way to see what's causing play. With the tires on the ground have a helper do quick left-right turns with the steering wheel while you closely watch the steering system and look for any side-to-side slop between any of the connections. Also note if the Pitman arm and steering box seem to be responding well to steering input. There is normal rotational play about the long axis of the tie rod, drag link, and track bar due to them being mounted on ball joints.
Speed sensitive shimmy is normally caused by either a bad front tire or an imperfectly balanced front tire.
Reactions: imactj2004
imactj2004
imactj2004
Bay Area
assuming I can isolate the slop, will new bushings be sufficient or should I replace the hardware as well?
cpwolf
Texan
TEXAS - Cedar Park
In the steering, Tie Rod ends are ball joints, you have to replace the TRE joint.
Bushings that could cause issue would be Control Arm bushings, start with the steering, own step at a time.
