Replaced some seals and cleaned it updid you just replace or repaint your oil pan or something? It's so damn clean and mine looks like butt.
Yes, it's designed to be able to move. Best to get both bushing ends mounted before tightening.Is that normal to have to pull down on it a little bit?
WHAT now you tell me...an I prob didn't need to pay for the American Strat too....Yes, it's designed to be able to move. Best to get both bushing ends mounted before tightening.
IIRC, the only part that is actually an upgrade is the tie rod.
Also, no need for a fancy damper, oem replacement is good enough.
There you go!My ball joint was stuck at the passenger side and I got it to rotate more so now where my steering damper connects to the drag link is way less vertical and more angled to the rear.
God I love this forum. Thanks for everybody’s help!There you go!
Yeah this damper just happened to be thrown in with all my lift components that I bought from a guy off Craigslist. All my old parts were in pretty rough shape so I just did it all at onceYes, it's designed to be able to move. Best to get both bushing ends mounted before tightening.
In my case it made sense but It’s definitely one of those things that doesn’t get put at the top of the-to-do list!you could guess from the photo I posted, but my steering damper is what came on my TJ when I bought it in 2017, and it already had that rust on it IIRC. I have not been motivated to do anything with it, but it might literally be the only thing below the frame on my entire rig that I haven't replaced or refreshed in some way.
