Steering question
NWPA Jeepy T
NW PA
I'm trying out my new steering disconnect to prevent theft
Seriously, PO made the tie rod and drag link - 1 ton steering. Ends, he said, are 90s GM with 7/8 thread. Having trouble finding them. 6 3/8 from end to grease fitting, 7 1/2 overall, 3 1/2 from thread to grease fitting. Calipers said .86" or 21.9mm for threaded end. Anyone have an idea on part for this? Drag link to pitman in this application
Thanks
Man I went through a similar ordeal once- if you will get on the moog website it will give you the specs on every drag link/ tie rod end they sell- its a big chart and has the thread, left hand/Right hand , length and taper (I think) -
It took a little work but I was able to find the one I needed.
Reactions: NWPA Jeepy T
Oof, rather than chase this, I would do the Moog ZJ conversion for lower cost, or a Currectlync if $ aren’t an issue.
I had the ZJ on my last TJ and it was great. I'm not sure why he built 1 ton steering for a 4.0 on 35s - seems overkill. I'll still look at Moog like AndyG suggested first and go from there
