They delivered the ideal gearing — ideal for Chrysler, not for each of us with our own criteria.
Which of the many gearings for the TJ was ideal for Chrysler?
... My point is the same as yours, there isn't an ideal.
Would you agree that some are less ideal than others are?
..., and almost none are ideal for we owners.
But would you agree that some are less ideal than others are (for we owners)?
Of course. That's why we change them. And discuss, and argue, about the ideal ratio.
Out of curiosity, I loaded the stock Rubicon data and my regeared data into the calculator at the Grimm Jeeper's gear ratio calculator. http://www.grimmjeeper.com/gears.html
Check the attached. My '03 Rubi with 33s and 4.56 gears is almost exactly the same as the stock Rubi. BTW, I have a NV3550 transmission.
Next trip out I'm going to check that against actual RPMs, MPH, etc.
IMHO, this confirms @Jerry Bransford assertion that 4.56 is the right ratio for 33" tire size and a 5-speed. Unless of course, you are into serious rock crawling. Alas, I'm a mere mortal and quite happy with moderate wheeling.
Don't regret it at all.
That’s my point. Your recommendation is based on your personal experience. Not some categorical understanding of the ideal gear ratio.
My own desire to regear as deeply as possible, is based on previously owning a similarly undergeared SUV (0.62:1 overdrive I believe).
These gearing discussions are nothing more than “my truths”, some being more commonly accepted than others.
.... Maybe some day an engineering student can do months worth of work for us and make a spread sheet?
They are too lazy to do any of that.
In the mean time its easy to just not gear like you have a big block pickup and a granny trans.a lot of the shitty gear recommendations come from non overdrive guys and get carried forward by the rest of us.
Even the cj community is starting to recognise there are a few gear steps between one and the other. Probably 3-4 gear steps with a 42rle
It’d be interesting to experience an overgeared TJ. Something like 5.38s on a 32RH and 31s.
I got a couple engineering major buddies, but none that are that invested into Jeeps
We have that to some degree by treating the 42rle as a 3 speed and ignoring the OD. Which means many of us know what a 32rh is like when geared to 5.38 and pushing 35s.
42rle/33.875"/5.38=4002rpm @ 75mph in 3rd gear
32rh/33.875"/5.38=4002rpm @ 75mph
The 32rh needs to be geared to 3.73 to closely match the OD of the 42rle. This is udergeared for both, as evidenced by the factory gearing of the 32rh.
42rle/33.875"/5.38=2762rpm @ 75mph
32rh/33.875"/3.73=2775rpm @ 75mph
Hold up, so a 32RH is just a 42RLE w/OD off. Very interesting.
I’ve driven a 32RH TJ w/ the same gearing/tires as I have now, and the driving experience felt different somehow.
