Front Spring Removal
I've included the tools and torque spec for each fastener in parens, even for disassembly where it's nice to know how hard you
should have to push on a bolt to get it loose. These specs are for my 05 Sport. I don't know if other models or years might have different fasteners or specs, so check yours before you start wrenching.
1. Place the vehicle on a level surface with the transmission in park (or in gear for a MT), the transfer case in 2H and the parking brake set.
2. Measure the front spring height and shock position.
View attachment 50142 View attachment 50143
3. Disconnect sway bar links at axle. (18mm & T55, 75 ft-lbs.) — FSM says to do this after jacking up and supporting the vehicle, but I found that the bolts are under load if you do that and it's hard to get them out. If you do this while the vehicle is sitting on level ground, there should be little to no tension on the bolts. I had to lift up slightly on bumper to slide the bolt out, but then my Jeep was sitting a little low.
View attachment 50144 View attachment 50145
4. Disconnect sway bar links at sway bar and remove old links. Use a puller tool to separate links from sway bar. (15mm, 45 ft-lbs.) — You don't have to do this if you're just swapping springs, but my links were shot so I replaced them while I was working on the springs.
View attachment 50148 View attachment 50147 View attachment 50146
5. Remove the track bar from the axle bracket. Loosely tie the track bar to the bracket in a position clear of other components. (15mm, 40 ft-lbs.) — This is another step that FSM says to do after you've jacked up and supported the vehicle, but the bolt will certainly be under load if you do that. Getting this bolt out while it's under load is a PITA and you risk damaging the threads. If you take out this bolt while the vehicle is sitting on level ground, there should be little to no tension on the bolt. If you do need to release tension on the bolt to slide it out, have a friend do a little dry steering to gently shift the position of the frame relative to the axle.
6. Chock the rear wheels. Raise and support the vehicle.
View attachment 50151 View attachment 50150
7. Position a hydraulic jack under the axle to support it.
8. Remove the front wheels. (Tire iron, 100 ft-lbs.)
9. Support the axle with jack stands.
10. Remove the right side of the drag link from the right-side knuckle (19mm, 55 ft lbs.):
· Remove the cotter pin and nut at the steering knuckle.
· Remove the drag link from the steering knuckle with a puller tool. — It helps if you steer to the left first, because this opens up a better position for the puller tool.
· Loosely tie the drag link to the knuckle in a position clear of other components.
11. Unmount the front shocks from the axle. (13mm long & 10mm box end, 21 ft-lbs~250 in-lbs.) — Technically you only need a short 13mm socket, but I had trouble getting my wrench into position with a short socket. A long socket or a socket extension helps.
View attachment 50160 View attachment 50159
12. Lower the left side of the axle until the spring is free from the upper mount, or until the lower suspension arm contacts the axle bracket. — I was able to free the spring without interference from the lower suspension arm, but you might have trouble if you have a lift kit.
View attachment 50164 View attachment 50163
13. If necessary, remove left lower suspension arm mounting nuts and bolts from the frame. (21mm & 21mm box end, 130 ft-lbs.) — FSM says you need to do this even for stock springs, but I was able to get the spring out without touching these bolts.
14. If necessary, lower the left side of the axle further until the spring is free from the upper mount. — I didn't need to do this because my springs were already free.
15. If necessary, remove the left coil spring retainer clip. (13mm, 16 ft-lbs.) Remove the left coil spring. NOTE: Rotation of the spring and prying down slightly on the axle will aid in removal. — My Jeep doesn't have a spring retainer clip. You can yank on the spring to slightly compress it while putting a foot on the hub to push the axle down.
16. Return the left side of the axle to the starting position and support with jack stands.
17. Pull the left jounce bumper out of the bump stop cup. — Not necessary if you're just swapping springs, but I replaced all the rubber components too.
18. Remove the bump stop cup. (15mm, ?? ft-lbs.) — I couldn't find a torque spec for this bolt. It's not in too tight, though.
19. Remove the left upper spring isolator. Use a screwdriver to pry the isolator free. — Not necessary unless you're going to replace it as I did.
20. Install the new spring isolator in the top spring mount and seat it fully in the spring mount. — Again, only necessary if you're replacing it.
21. Reinstall the bump stop cup. (15mm, ?? ft-lbs.) — I couldn't find a torque spec for this bolt, so I just tightened it up about as much as it was when I found it.
22. If necessary, reinstall the left lower suspension arm mounting nut and bolt and hand tighten. (21mm & 21mm box end, hand tight.) — I didn't remove this bolt.
23. Lower the right side of the axle until the spring is free from the upper mount, or until the lower suspension arm contacts the axle bracket.— I was able to free the spring without interference from the lower suspension arm, but you might have trouble if you have a lift kit.
24. If necessary, remove right lower suspension arm mounting nuts and bolts from the frame. (21mm & 21mm box end, 130 ft-lbs.) — The spring was already free, so I didn't have to do this.
25. If necessary, lower the right side of the axle further until the spring is free from the upper mount. — I didn't have to do this, but you might have to if you have a lift kit.
26. Remove the right coil spring retainer clip (13mm, 16 ft-lbs.) and remove the spring. Rotation of the spring and prying down slightly on the axle will aid in removal. — My Jeep doesn't have a spring retainer clip. Pulling out the right spring is easier than the left spring. I just slid it right out.
27. Return the right side of the axle to the starting position and support with jack stands.
28. Pull the right jounce bumper out of the bump stop cup. — Only if you plan to replace it.
29. Remove the bump stop cup. (15mm, ?? ft-lbs.) — I couldn't find a torque spec for this bolt.
30. Remove the right upper spring isolator. Use a screwdriver to pry the isolator free. — Only if you plan to replace the isolator.
31. Install the new spring isolator in the top spring mount and seat it fully in the spring mount.
32. Reinstall the bump stop cup. (15mm, ?? ft-lbs.) — I couldn't find a torque spec for this bolt so I just tightened it about as much as it was when I found it.
33. If necessary, reinstall the right lower suspension arm mounting nuts and bolts and hand tighten. (21mm & 21mm box end, hand tight.) — I didn't have to remove this bolt.
34. Measure the old spring lengths and the new spring lengths. — The moment of truth. The old springs were a little more than 1/4" shorter than the new springs.
View attachment 50187 View attachment 50186 View attachment 50185
