Well, it happened. Stripped the drain plug on the transfer case. Fill plug came out fine. After heat, PB blaster, tapping - thought it was coming out..but stripped instead.
Any tips/tricks? First instinct is order an ez-out that will fit nicely in the nice round hole that's there now. If that doesn't work...weld a socket to it?
Really need to remove it to drain fluid as I got some water in the transfer case fluid. I know...I know....
