Was gifted a TJ with F&R ARBs in the otherwise stock Dana 30 and Dana 35 axles with 3.07 gears and ABS. The Jeep has 31's, belly-up, and a 2.5" lift. The Jeep has been over the Rubicon and Dusy multiple times and hopefully will continue to do so now that I have it. Although I miss my previous TJ which was far more capable on the trail, I do appreciate the street manners of the lower Jeep with smaller tires.
I've been out of the Jeep world for several years and it's been even longer since I've had one with a Dana 35. I'd like to beef up the Dana 35 axle shafts because swapping them out on a trail is not my idea of fun. I know that the Super 35 seems to be the go-to answer for beefing up the axle, but I'd rather not replace a perfectly functioning Dana 35. Additionally, I can't really do much with the gearing due to the carrier split.
Are there any aftermarket 27-spline Dana 35 axle shafts which provide a notable increase in strength? All things being equal, I'd like to retain the ABS, though it is not essential if I can increase the strength of the axles.
Thank you!
Thank you!
