Last weekend, I tried to change the fluid on my T-Case (NV-241). I started by trying the fill plug and proceeded to strip the stupid soft metal they used on those bolts. As is often the case, the steel and aluminum have gone through galvanic corrosion. I assume they are locked right together. Thought about grabbing a 10mm hex wrench to weld into the socket on the drain plug. Nervous about putting that much heat into the T-case though.
Any ideas?
Any ideas?
