so i just got a 98 wrangler sport but it didnt have a console sub and i was wondering about peoples solutions to this problem while still keeping the tiny trunk space and rear seats in if there are any out there
Thank you this whole jeep things pretty new to me. Thank god the community is great!@Rob5589 has a slick setup using a powered sub he mounting inside the bottom of the rear seat. I mounted a slimline 8" sub in my center console. Took a little fab work to do it. I, like you, didn't have a factory sub and just an empty pocket.
Under the rear seat mounted to the bottom of the seat. Get a powered sub like the ROckford Fosgate PS-8 $$ or Sound Ordnance $ or Kicker $$$so i just got a 98 wrangler sport but it didnt have a console sub and i was wondering about peoples solutions to this problem while still keeping the tiny trunk space and rear seats in if there are any out there
Also @bobthetj03 how is your setups sound quality and can i see some pictures of the setup
On mine it takes about 5 mins to detach the cabling and remove seat. The amp stays in place.@JMT and the rockford fits under im expecting but how easy is it to detach it to remove the seat when needed
It’s 4 screws to remove, plus wiring that simply unplugs from the amp. Not long at all. Much less than removing my hardtop with a hoist@JMT and the rockford fits under im expecting but how easy is it to detach it to remove the seat when needed
Ive been looking at both that rockford and an alpine one but is installation as simple as boltong it to the bottom of the rear seat and wiring it to the radio?It’s 4 screws to remove, plus wiring that simply unplugs from the amp. Not long at all. Much less than removing my hardtop with a hoist
I'll take some pictures later, unless @Rob5589 beats me to it. In short, cut a piece of 3/4" plywood slightly larger than the footprint of the sub/amp. Cut grooves in the board where your metal straps are underneath the seat. Sneak the plywood base under those straps. Bolt the sub/amp onto it. Run your wires. Enjoy!Ive been looking at both that rockford and an alpine one but is installation as simple as boltong it to the bottom of the rear seat and wiring it to the radio?
Use the other seat! There’s more than one way to skin a cat!@Steve Rodgers thats an interesting idea if i dodnt have a lock box under there for my stuff with the top off id do that for sire
