Airjunky
Any pics of the sub box you used on the 8?Mine actually sounds better with the top off, but my 8" sub is hitting the side of my hip, so not a lot is lost.
Nice! So this is a sub box you built?My jeep didn't come with a factory sub, so I did some fab work to the storage enclosure and basically made it a sealed sub enclosure for a slime line 8.
I think I’ll start by adding another strip of wood at the bottom and seeing how that works. I’d like to do some straps like Rob did, if I can find some laying around. Looks nice! Good ideas! Thanks...another projectI’ve been brainstorming and searching, and I found this picture below on another forum. It gave me some ideas.
Option 1. Cut a new length of plywood that would fit in the full front to back width of the seat, this would basically lodge it between the forward and aft large metal supports and should keep it from moving front to back. You would still need to cut the grooves to keep it from moving left to right (or see option 2 below).
Option 2. Some type of metal strap screwed tightly into the existing plywood on each side of and over the metal straps. The picture shows something like this, although I’m sure he used that to hold left to right position instead of cutting grooves like you did. However using grooves and metal straps like this could hold it in one spot if you could get them tight enough. I’m assuming that cutting 1/4” deep grooves also helps the set up sit a little lower and not press up into the cushion as much.
Option 3. Put hose clamps on all 4 corners where the metal straps meet the plywood grooves. Maybe that would hold it in place.
I’m thinking about doing the longer length section of plywood. Cutting 1/4” grooves. Then using metal strips as well, like in option 2. I bet doing that would keep that sucker in one spot. I’ll have to wait a month or so before my play money builds back up to order the sub. I just bought a new head unit and 4 new speakers.
What are your thoughts about that?
I just slipped a piece of wood in there this evening. It had been staying put for awhile, so it may not be much of an issue.Please let me know how that works out for you when you get it done. Hopefully it works out great! Dang Jeeps are never freakin ending projects.
That sounds like an easy fix then. Glad to hear it. I’ll cut my plywood to be the full length and that should take care of it. I’ll still do the grooves like you did and may try to do the strap thing. Thanks for the help!!I just slipped a piece of wood in there this evening. It had been staying put for awhile, so it may not be much of an issue.
Crimp on an eye connector and run a ground wire to one of rear seat mount bracket bolts. Get a 3 prong connector and wire it in so you can easily disconnect the harness if you need to take the seat out.
https://www.amazon.com/dp/B0160G7IHA/?tag=wranglerorg-20
Good idea, but the PS-8 Amp makes it easy with a plug for the ground, accessory and power that just unplugs from the amp when you need to pull the seat.Crimp on an eye connector and run a ground wire to one of rear seat mount bracket bolts. Get a 3 prong connector and wire it in so you can easily disconnect the harness if you need to take the seat out.
When you ground, don't forget to sand all the paint off so you get a good ground.Good deal. That’s what I’ll do. Thank you sir!
You’re going to love it. And the bass control knob, you’ll be tempted not to install it, but I love mine, much easier than entering your head unit settings and making a bass adjustment. I literally use it everyday.Will do! I ordered my Rockford Fosgate PS-8 from Crutchfield today. Hopefully I’ll get to install the full new system over the weekend.
