Jerry,
So you are recommending the no slip lunch box up front and the Truetrac LSD in the rear withe 5.13 gears ? Can I stay with the stock rear 27 spline axles or should I go to the 27 spline alloy axles unless you recommend going to 30 spline axles. Just trying to clarify all the information that has been shared.
Greg
Truetrac LSD in the rear is a good choice. Great for winter, and because they don't fully "lock", it will be less prone to breaking a 27 spline rear axle. (less prone than a locker, but more prone than an open diff)
As for the front - you live in Minnesota...so I would NOT recommend an automatic locker. (lunch box). Nope.
The lunch box works great for people
who do not drive in the snow. But a lunch box locker can be unpredictable and dangerous in snow or ice. (You can be driving along nicely, then be immediately turned around 180' due to the auto locker deciding to engage on it's own).
In the summer, it will be awesome...but in winter...it will be fine for "most" of the time, until the one time it spins you off into ongoing traffic. If you do put a lunch box up front, do not engage 4x4 in winter on the streets or highway.
For the front, I'd recommend either a selectable locker, another TrueTrac up front, or keep it as an open diff.
I personally have a TrueTrac in my rear, and will have a TrueTrac in my front by tomorrow (I hope). I also live north of you.
The Detroit TrueTrac (not to be confused with the Detroit locker), is a LSD, and therefore works nicer in snow or on ice than an auto "locker".
The selectable locker is good up front because YOU decide when it's locked or unlocked. It can provide arguably superior traction when engaged and 4x4'ing and driving straight, but you can lose traction (laterally) and have difficulty steering.
An open diff isn't going to help you much when 4x4ing (what you have right now), but is not going to do anything unpredictable in snow or ice.
I chose a TrueTrac up front over a selectable locker because of a few reasons:
1. price
2. reliability (some people have issues with moisture freezing the air compressor lines. The TrueTrac does not have that issue - it doesn't even have clutch packs to wear out. It's just always going to work.)
3. it's (arguably) better in snow/ice, especially if steering in tight trails.
4. My Jeep is my daily driver.
As I've never 4x4'd with it yet (I plan to this Sunday), I cannot comment if I made the right choice or not. But that was my reasoning vs a selectable up front.
I'd also say that a 5.13 gear on a Dana 35 is a really small pinion. That might be too low for that axle combo in some people's opinions, but I can't say for sure.
