Goals
- Replace the worn out tie rod ends and whatever the ends are called on the drag link (sockets?)
- Keep the LJ near stock (no drilling, cutting, new wheels, etc.)
- Should still be a DIY project for a kinda-newbie, since that's why I went with the LJ (i.e. no fabricating or exotic tools necessary)
- Willing to spend money on parts, especially ones that are serviceable and heavier(?) duty
What I've Found Out So Far
Looks like I can replace the tie rod ends and the inner socket (drag link to pitman arm), but the socket on the other side of the drag link doesn't look like it is replaceable (if it is, then you can skip the rest and just point me to instructions for this). Since this is a wear item, it would be great if the new equipment was more serviceable.
In researching replacement parts, I found a couple of "steering kits" that include all new tie rod and drag link assemblies. This seems like it would make the installation go easier and then all of the components would be refreshed.
However, anything "heavy duty" or with replaceable ends seemed to require drilling out the tapered receiver on the knuckles, is intended for lifted applications (Currie, Rugged Ridge), or weren't compatible with stock wheels (Rugged Ridge).
Looking at OEM-style replacement kits (usually Crown), the tire-side of the drag link is not replaceable (RT Offroad) and all the reviews complain about bad zerk fittings (Crown) and cheap rubber boots/early wear (again, Crown). [Note: The Crown hardware is often labeled "heavy duty", but I can't find anything in the descriptions to indicate that they are any thicker or more serviceable than OEM]
What To Do?
- Just get the Crown and expect to replace it regularly?
- Go with a make-your-own-kit using Moog tie rod ends and a replacement drag link?
- Get helpful suggestions for previously undiscovered options from the friendly folks on the WranglerTJForum?
I guess I'm starting out with the last item. Thanks in advance.
[Did you make it to the end of this post? Holy Carp! Another obsessive! Glad to meet 'cha!]
What To Do?
