Summit Dual Air Compressor
jesseshoots
Atlanta, GA
I was scrolling thru Instagram and came across an ad for Summit Offroad. They’re advertising a 10.6 CFM compressor with 50% duty cycle for under $200 and its portable. I like that because I can take it out to use with another vehicle if I’m not in the Jeep or don’t want to take it.
I’ve been pretty dead set on a York setup but this one has me thinking otherwise. My only hesitation is the duty cycle. Thoughts?
Specs:
10.6 CFM @ 0 PSI
6.36 CFM @ 29 PSI
50% duty cycle
LJBean
TJ Fanatic
Union Valley, TX
I'm interested in this. Does anybody have specs/dimensions? I've got a modified Smittybilt compressor mounted in my engine bay and would love to be able to double the capacity if there is room.
WSS
Rock Stacker
California, southern part
These are half the amps even under load and 100% duty cycle.
Lou
This forum has gone to shit
Long Beach
I know a guy who has one and he swears by it. He runs 40s and says it is significantly faster than his previous ARB twin and smittybuilt. I havent seen it in action yet.
Jerry Bransford
TJ Guru Moderator
Staff Member
Escondido California
Specs:
10.6 CFM @ 0 PSI
6.36 CFM @ 29 PSI
50% duty cycle
Forget that 10.6 CFM rating, that's a totally misleading rating. Your lungs can put out 10 CFM into a 0 psi back pressure (open air). 6.36 CFM into 29 psi (like into an aired up tire) tire) is the real spec and that's actually a really great CFM rating. That's a great deal for a 6 CFM compressor.
Irun
Jeep Addict
Virginia
According to the weight, this thing is beefy! At 26lbs, it's only 4 pounds lighter than this
WSS
Rock Stacker
Jerry Bransford
TJ Guru Moderator
Staff Member
I run a CO2 tank. But I have room for it.
It doesn't take much room, mine is up & out of the way adjacent to the rear roll bar. I still miss my York belt-driven compressor I installed onto my previous TJ but my homemade CO2 tank fills tires just as fast, which is to say all four 35" tires tires refilled from 8 to 25 psi in around 5 minutes total.
