I have a 2004 TJ that I am going to supercharge.
Can someone tell me what horse power & torque can the standard running gear take?
That pretty much eliminates the reason for the supercharger. At least that why I would buy one.I have a supercharged TJ that puts down roughly 210-220 at the wheels with around 260-270 torque.
Believe me when I say that your stock transmission and driveshafts can definitely handle that power. As long as you're not drag racing people, doing stupid burnouts or being an all around asshat with the throttle, you'll be just fine!
220hp at the wheels really isn't that much in all honesty. It's enough to totally transform the vehicle, but it's not enough to worry about snapping axles or anything.
I only see the stock manual transmission not holding up. But like you said it would be dumping the clutch and racing it.I've got RCV axles in the front, Revolution chromoly axles in the rear, Vanco big brakes, 4.88 ring and pinions, D44s... The list goes on.
I'm not worried about being stupid with the throttle. I simply meant to say that if you're running stock axle shafts it may be a good idea to not be a complete goon with the throttle.
In my case though I'm not worried about that at all. My entire drivetrain is built more than enough to handle 220hp at the wheels
But hey, I've never tested a supercharger on a stock drivetrain. At only 5-6 psi I personally don't think you'd encounter any issues at all with stock components. I'm just telling him to err on the side of caution is all.
My Chevy 6.0 liter stock puts out 360 hp and 390 torque. Mine isn't quite stock-- front and rear diffs are the stock D44s and have help up so far.
What's torque specs on those gears and axles? Cot and mot
Sent from my VS990 using Tapatalk
This is my first Wrangler, daily drive, I'm 53 & not a complete idiot. Ask my wife
I'm starting a new business, super finishing & impinging of tungsten disulfide, on engine, transmission & general engineering parts.
The gear is still on its way here (New Zealand), so I'm building this as a marketing tool in the mean time.
Something that appeals to the engine heads, like me & the straight peak, baggy pants guys.
If I pop the bonnet, guys cant see a big bore but can see the blower & gear.
It's an 04 so I'm looking at the Ripp Tuner Kit. I will fit an after market ECU & wiring loom. I will make a 3" stainless steel exhaust & snorkel for it.
It has a heavy duty clutch, headers, 62mm throttle body, 2" lift & 33" tires already.
A mate that builds muscle cars will do the wiring & dyno tuning.
We hope to get a bit more than the 220hp & 270ft/lbs that Ripp claim but still want to be able to take the dogs to the beach and go fishing in it.
400hp that's insane with such a short wheel base
Does he run the standard running gear?
People told me to drop a V8 in mine but I like the fact that it's not a fashionable engine. So old school & something different to work with.
There's an engine for sale for $400 here as there not used to re-power any thing & the boy racers don't want them.
If things go well, I'll buy a spare and rebuild it with all the internals polished like these cranks
