john arata Member Joined Dec 9, 2015 Messages 69 Feb 21, 2016 #1 Im doing the back now what size bolt did you go with and how long,if I go with the half inch like bolts from front bumper i have to drill holes bigger.Also will I need washers on the inside
OP john arata Member Joined Dec 9, 2015 Messages 69 Feb 21, 2016 #2 also do the nuts have to be hardened also like bolt
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 3,893 Location Brookings, Oregon Feb 21, 2016 #3 john arata said: also do the nuts have to be hardened also like bolt Click to expand... The OEM recovery hook for the rear used a 1/2 x 13 bolt with a flag nut to fish into the frame.
OP john arata Member Joined Dec 9, 2015 Messages 69 Feb 21, 2016 #4 but the bolt hole on the frame is smaller then 1/2 inch
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 3,893 Location Brookings, Oregon Feb 21, 2016 #5 I wouldn't use anything less than 1/2 for a recovery hook, a uni- bit generally works nicely on that.
Zhillslady TJ Enthusiast Joined Dec 10, 2015 Messages 255 Location Zephyrhills, FL Feb 22, 2016 #6 Keep asking. I'm looking to put some on front of my jeep. Didn't think to add to the back also Reactions: Chris
