Soo I was following the JB Conversions install document and it neglects to mention removing the front DS and yoke nut entirely. So here I am, TCase split apart, with that huge nut still bolted on nice and tight. Is there any trick to immobilizing it so I can remove it? Or do I need to put it back together just to get that nut?
I tried putting on the rear DS but it appears to be stuck in Neutral now, the selector inside doesn't want to go to 4lo or 4hi. Assuming there is something the back half of the case does to let you shift gears? Maybe there is a way to manually select 4lo and chock the rear tires to get the nut off?
Man I much prefer written instructions so I was stoked to just be able to read that PDF but now I feel soo dumb for trying to use it
