I would not have done the video the way I did were it not for me witnessing many sets of rigging on trails where the tubular abrasion guard was run over a knife edge and I picked it up and put a wadded up sweatshirt under it to save the rope.I'm not advocating for the abrasion guard, I'm saying the comparison is has some flaws. The comparison clearly shows that the other guard is much better, but a more realistic comparison would tell us whether they are good enough.
You can't fault me for missing a point that wasn't in the videos. The videos don't show what the guard looked like afterwards. So it's a reasonable assumption that the rope broke from rubbing against the guard while under a tensile load, and the guard didn't because it was only subjected to the friction.
Once again, the comparison isn't realistic because the rope is being run over a knife edge which really increases the stress due to the small contact area. While yes the woven guard was terrible in that scenario, the videos don't prove that they wouldn't work over an edge with a much larger radius. I definitely suspect that they wouldn't be up to snuff, but there's no proof in the videos.
Sadly, even well known companies have hopped on the recovery gear bandwagon and it is clear from their products that knowledge does not equal understanding. One of the worst offenders is Poison Spyder. Their hawse fairlead is barely radiused around the opening.I have learned more than I ever knew about mounted winches than I knew before, by reading these posts.
The Warn fairlead had half as much radius on the inside as the outside, you would think they would be the same.Sadly, even well known companies have hopped on the recovery gear bandwagon and it is clear from their products that knowledge does not equal understanding. One of the worst offenders is Poison Spyder. Their hawse fairlead is barely radiused around the opening.
How does that matter, the line only varies in angle from a full to empty drum? Let's be realistic, there isn't a need for anything other than proper clearance on the inside and a very small radius to be sure you can fully load the drum and empty it without hitting an edge.The Warn fairlead had half as much radius on the inside as the outside, you would think they would be the same.
Can't argue with that, surprising that the rope bends so much going to the drum, mine is almost a straight shot but I've got an old steel hawse (and steel line).I thought the same as you but the evidence is melted rope on the inside radius.
The TRE Has the same radius inside as out, which seems would give the rope less friction exposure.Can't argue with that, surprising that the rope bends so much going to the drum, mine is almost a straight shot but I've got an old steel hawse (and steel line).
It’s aluminumSo that black shmeg on the Warn pictures is the rope? I thought it was damage to the finish on the fairlead, just figured it out. Was your Warn steel or Al?
Your test rod needs to move down to the top of the bumper. That is a scenario that the line will see when it stacks up on one side.Update! The need for a new fairlead led to a whole new front bumper and shedding 35lbs.
I ended up with a Motobilt stubby to replace the heavy old square tube anchor.
What matters here is fitting the TRE fairlead.
While the width is more than adequate, Motobilt's fairlead mount opening is not tall enough to clear the TRE scribe line.
However, I when I use this piece of tube to trace where the rope will feed, ....
... I could not find a position where the rope could contact the mount opening. As best as I can tell with this particular arrangement, I shouldn't need to widen the opening.
Does anyone see something I'm not seeing or know something I'm not knowing?
How ironic, the need for a new front license plate holder lead to this:
View attachment 108651View attachment 108652
