My Warn Zeon wiinch has synthetic rope on it. Not thinking of changing, just wondering about safety factors. Does synthetic rope recoil like steel cable?
Contrary to the myth that is still being perpetuated about synthetic just dropping to the ground when it parts under load, yes, it does recoil exactly like steel cable when it parts under load. The difference is mass x velocity = the potential for damage. In the case of synthetic, the mass is 1/6- 1/8th the mass of steel cable so even though the velocity is similar, the total force delivered when it smacks into something is much less.My Warn Zeon wiinch has synthetic rope on it. Not thinking of changing, just wondering about safety factors. Does synthetic rope recoil like steel cable?
I would also think that when a synthetic line parts it would loose velocity at a faster rate than steel - less weight to overcome air friction, etc. Further reducing the force with which it could strike an object (or person).Contrary to the myth that is still being perpetuated about synthetic just dropping to the ground when it parts under load, yes, it does recoil exactly like steel cable when it parts under load. The difference is mass x velocity = the potential for damage. In the case of synthetic, the mass is 1/6- 1/8th the mass of steel cable so even though the velocity is similar, the total force delivered when it smacks into something is much less.
A way to visualize it easily is you grab 3 feet of steel cable and your buddy has 3 feet of synthetic. Ya'll take turns hitting each other and see who quits first.
ya. that's the mass vs velocity equation., Blaine mentions.I would also think that when a synthetic line parts it would loose velocity at a faster rate than steel - less weight to overcome air friction, etc. Further reducing the force with which it could strike an object (or person).
Does that make sense?
I'm not that smart but watching the speed the line moves when it parts should help you figure it out.I would also think that when a synthetic line parts it would loose velocity at a faster rate than steel - less weight to overcome air friction, etc. Further reducing the force with which it could strike an object (or person).
Weight bags require the use of a crystal ball, how is yours working?those hanger bags made to drop the line would/should be much more efficient vs a synthetic line.
not well enough to follow ..plz explain.how is yours working?
If you depend on a weight bag to try and slow down the line's speed, you have to be able to predict where it will break. You can't.not well enough to follow ..plz explain.
i said more efficient due to mass it's handling not if it was actually needed. but if you have an opinion of them plz share.
valid point.If you depend on a weight bag to try and slow down the line's speed, you have to be able to predict where it will break. You can't.
We work recoveries with folks in the danger zone of synthetic often. We don't with steel, ever. I've seen a lot of synthetic breaks and two things are generally true, it doesn't break due to high load, it breaks due to something damaging it since your winch isn't powerful enough to break it. That means it is a low force failure with little energy. The second thing is while I wouldn't want to get hit, it isn't a hospital visit if I do unless I'm doing something extremely stupid in which case I deserve it.valid point.
i don't care what winch line you run i cringe evry time i see a video with a taught line and some fool reachin out to grab it. or 3 guys talking smack standing within 3ft of it.
Ronnie Dahl.there is a vicious video if steel cable breaks, i have posted this b4. it rips vehicles and mannequins to pieces and shows how fast that line can get loose and what it can do and it's horrifying to see the destruction the cables are capable of. those lines don't come straight back either if your within 15' of it your not safe as it recoils whipping back and forth.
In my case above, I was doing a bit of a side pull and the rope parted at the poorly cast Warn hawse fairlead. I switched to a TRE aluminum hawse immediately after.We work recoveries with folks in the danger zone of synthetic often. We don't with steel, ever. I've seen a lot of synthetic breaks and two things are generally true, it doesn't break due to high load, it breaks due to something damaging it since your winch isn't powerful enough to break it. That means it is a low force failure with little energy. The second thing is while I wouldn't want to get hit, it isn't a hospital visit if I do unless I'm doing something extremely stupid in which case I deserve it.
I don't believe they are poorly cast and polished, I think the porous nature of it just being a casting is the problem.In my case above, I was doing a bit of a side pull and the rope parted at the poorly cast Warn hawse fairlead. I switched to a TRE aluminum hawse immediately after.
ripped through everything. oops, you got no head. oh snap, your leg is over there......hey look, we have a convertible now.cable ripped through them like they weren't even there.
i have not watched it entirely for some time now......i never had 1 in my hands but i don't see the weight or construction in those saddle bags to contain a cable failure. i think i'd be more efficient vs the synth line but then we play Blaines point of guessing where it's gonna rip.
TRE doesn't say cast or billet and there could be a spectrum of cast quality based on who and where it was done, no?
