So I confirmed functions with multimeter. I made the connections by just twisting the wires but none of the lights are functioning.
Leads me to believe one of two things:
- Need better connections (solder)
- Lights are dead on arrival
I’m not great with how to test that the wires work but does it make sense that nothing would work if the connections are not super strong? I’m worried that if I solder everything it still isn’t going to work.
When you say " confirmed functions with multimeter", do you mean that you checked Voltage? If you're getting voltage, the system is functioning properly, the lights aren't. How are these grounded? You don't mention a ground wire. The factory lights are grounded when screwed to the body. If the same, you need to make sure that you have a good ground when testing. If not, make sure that the ground wire is connected solidly.
When you make your final connections, use crimp on connectors. I like to use UNINSULATED connectors with heat-shrink over them. Use a GOOD crimper, not the cheap junk you can get everywhere. If you think that someday you might need to remove them for some reason, insulated spade connectors work well.
