Modded the kids room too, gotta' raise them right!
Good luck with Nth Degree. Check out my thread on them.
As far as temps, you are in the normal range for the 4.0. The best cooling system for it is the factory equipment in good working order.
Awesome build. Id like to know more about your redneck cruise control.
Ok looks cool. Ever tried riding down the highway? Lol
Does it work pretty good? Like is it a kit or something you fabbed up?Yep! lol.
Awesome looking tires by the way.
Looks good! I have that same currie setup and it is well made. All their stuff is if you decide to go for their antirock also.
Are you going to upgrade the Dana 44 axles at all or go for the light foot with the 35"s?
Be prepared to remove your front bumper to install the antirock. I had allocated 4 days to do everything with the suspension and I may have been a little optimistic on my abilities.Antirock is in the cards
I already put chromo shafts in the rear when I first got her (leaky axle seal grooved stock shaft) so that is good to go.
Also these 35s are pretty light weight compared to some other ones (67 lbs vs 81+ lbs), so that was part of the decision to buy
You understand the beef difference between the stock steering and this kit well then! haha.
Have you regeared? I am trying to feel out the order of how I need to go if I can make my 33"s last till next spring I will have some more flexibility. Regearing and new shafts are also planned for the Dana 44's.
All the currie stuff is top notch. I'm now running the savvy/currie combo and it was worth the cost.
