TeraFlex 2204000 231 2Low - $245.64 and possible additional 5% off
And driving on pavement when you want to go slow. Of course, the weird shift pattern the 2-low kit gives you negates some of the advantage, but it is what it is...
I installed the Terra 2-low. 2-Low is quite functional but I have had problems popping out of 4-Hi since i installed the 2-Low shift selector. It's like the selector will feel in detent and 4wd light is illuminated but then it'll pop out after a bit. I have to shift into neutral then back into 4wd to make sure im all the way in detent.
I've heard there's some "adjustments" (read: grinding on something) that can be done to make that mo' bettah.
