Got all the u-joints out finally but the joint in the front driveshaft is coming apart. Going to order a rebuild kit before I can put it back together. Killing time and knocking other projects out while I decide what to do with the transmission.
Hoping you do some sort of write up! I have heard it's real hard requiring specialty tools and alternately heard it's pretty straight forward requiring only a good set of snap ring pliers.
Are there any clearances or backlash or anything like that requiring adjusting, or just take it apart and put it back together with hopefully no left over pieces?
The manual states where tolerances should be checked and there are thrust washers and spacers for those areas. Mostly it's take it apart and put it together though.
"using the AX-15 teardown manual" Where available ?? on line ??
Looking forward to hearing what it runs like installed
