Hey yall check out this jeep tj upgrade. I did this in a couple hours this morning. if you have any questions Ill be glad to share what I did.
I stopped reinstalling the #4 fuse years ago. Whenever I need the interior lights I just turn them on with the dashlight dimmer control.
As long as it continues to operate properly I think it will be a good mod.. the way it's wired makes it easy to go back to OEM style quickly. I'll let y'all know if things don't work out for sure.Don't get me wrong, that's really cool, but pulling my #4 fuse is easy, take 5 seconds, and goes back in just as easily.
Thanks for sharing this though!
Ha I didn't know that.I stopped reinstalling the #4 fuse years ago. Whenever I need the interior lights I just turn them on with the dashlight dimmer control.
#4 fuse pulled a year or more ago. Just turn them on by twisting the left turn signal knob. I use them a couple of times a week. Not understanding why anyone needs to go to great lengths.
Hi Tworley,I made a switch that breaks the circuit as well. Copied the design from one offered on quadratec. Everything is ran behind the dash and mounted to a 2-throw switch on the center console. Took maybe half an hour to make.
Hi Tworley,
How/where did you splice into the circuit? Quadratec switch uses some pins that get inserted into the socket for fuse four.
Thanks,
Fonz
They actually do. You can find them all over Amazon for a couple of bucks. Search for "mini fuse tap".its too bad someone doesn't make plug and play replacement switch that operates in the same manner.
I would do this, but I do not trust myself to turn my headlights off every timeI stopped reinstalling the #4 fuse years ago. Whenever I need the interior lights I just turn them on with the dashlight dimmer control.
Who needs headlights?I would do this, but I do not trust myself to turn my headlights off every time
