Not to revive this thread or anything, but I couldn't resist after finding this [emoji23][emoji23]
You have to give it to them... That's pretty ingenious!Not to revive this thread or anything, but I couldn't resist after finding this [emoji23][emoji23] View attachment 8079
Jeep drivers *always* find a way...
So does a tree limb!So it does serve a purpose after all
View attachment 8878 View attachment 8879 View attachment 8880 Two years ago I pushed too hard with my plow truck and got stuck. This was the first time I used my High-Lift as a winch. I anchored to the receiver hitch on my Durango and was able to free myself, and saved myself a $50.00 wrecker call.
I now have a 10,000 lb winch on my TJ.
On the High Lift safety issue... Most government departments have removed them because of the Workers Compensation injury issues. So yeah, unstable and prone to do things unexpectedly .... like driving the handle thru yer jaw.
Here ya' go. I have one and use it reasonably often. Works great to lift a tire out of a hole so you can fill the hole in.I Jeep alone and usually above tree line where there is often nothing to secure a winch to. While I have never needed it yet- the Hi-lift rides along in case I high center and need to stuff rocks/gravel under a tire. I do wish I had a sling that goes over the tire so I do not have to lift so high with the bumper. I would never crawl under anything sitting on a high lift- that is is for sure. We had an even more dangerous version on the farm called a railroad jack- that thing required a huge amount of respect.
No anchor points for the winch off to the side?Stuck in ruts, front axle against a stump/rock, no one behind you to pull you back.
I've been there. Tried getting winched and tugged forward, but the old WJ wouldn't move. Used a Hi-Lift on my rock sliders to lift it up, and put pieces of deadfall under a front tire. It brought it up high enough that I could be winched out.
In my case there was nothing strong enough. There were a lot of trees, but nothing thicker than 2".No anchor points for the winch off to the side?
