The Official LED Light Bar Guide
Chris
Administrator
Staff Member
Gillette, WY
There's an overwhelmingly large amount of options out there when it comes to LED light bars for our Wrangler TJs. Because of that I decided to create a thread that will not only allow for a meaningful discussion of LED light bars, but also outline some of your choices, the more reputable brands, etc.
Feel free to add to this thread as well! I don't profess to know everything, I'm just trying to help educate others.
LED Light Bar Types
LED light bars may contain one LED or dozens. The LEDs within a single bar are usually the same size but power sizes and colors can be mixed. For example, a police vehicle light bar may contain white, amber, red and blue LEDs of various strengths. Some or all of these may flash.
Mini Light Bars
The smallest light bars are often referred to as light pods. They are used as side lights, work lights or portable spotlights. Cubes of 4 LEDs are regularly used as fog lamps.
Full-size Light Bars
These are rectangular, enclosed arrays of up to 96 LEDs in a single bar. The LEDs may be arranged in single, double or quad rows.
The best LED light bar used for road or job site illumination has LEDs with a color temperature of 5000K, which simulates sunlight on a clear day. Custom reflectors or lenses spread, focus or diffuse the beam. Two or more beam angles are created in combo bars.
Low-Profile Light Bars
These light bars contain a single row of LEDs and are usually under 20 inches long. Their low profile makes them ideal for vehicle grill mounting.
Colored LED Light Bars
The range of colors available for LEDs runs from deep red to hot blue. There are even LEDs that emit UV and IR light, which often find application at your dentist’s office or for trail cams, respectively
What Is a Cree LED Light Bar?
In your search for the best LED light bar, you will come across the term Cree light bar. Cree refers to the LEDs in the light bar, not to the brand of light bar. All the light bars in this guide’s LED light bar reviews use a version of Cree LEDs.
Cree, Inc., located in North Carolina, manufactures these powerful, highly efficient LEDs. They are the highest quality, longest lasting, and most efficient LED lighting for homes, businesses and roadways.
The finest Cree LED light bars have an efficiency at the top end of the scale for LEDs approaching 120 raw lm/W. With proper current control, they have a lifespan over 50,000 hours. Unlike cheaply made LEDs, Cree LEDs do not fade early. Despite higher initial cost compared to other LEDs, in the long run they cost less to operate.
As an example, a popular light bar choice is a 20″ Cree LED light bar that contains 40 3-WCree LEDs. This runs at 120 watts and produces 9600 effective lumens.
Flood, Spot or Combo – Which LED Light Bar Do I Need?
Unlike standard screw-in home bulbs, which throw light out in all directions, LED light bars concentrate their light in one direction.
The way the light beam is formed depends on each LED’s reflector and the shape of the lens. Modern light bars use computer-aided designs to achieve specific lighting patterns.
The lighting pattern trade-off for light bars is between distance and beam width. For the same luminosity, more distance requires less beam width and vice versa. When a design favors a wider beam width, you have a flood light. More distance is achieved by narrowing the light beam into a spot pattern.
A flood LED light bar typically has between 40 and 120 degrees of beam width. Spots are around 10 to 30 degrees. Keep in mind that flood and spot degrees vary between different models of led light bars.
So which one is best? It depends on the application. Both are useful and a common choice is to buy one of each or purchase a combo bar that has spot and flood functions combined.
A combo works by assigning the jobs of the spot and the flood light to different sections of the light bar. It can do this by dividing flood and spot reflectors along the bar’s length or by splitting the functions between rows. The best LED light bar of one manufacturer allows you to custom design your flood to spot ratio with swappable reflectors.
Factors to Consider When Evaluating the Best LED Light Bar
Light Bar Length
Enclosed LED light bars typically come in the following lengths: 4 inch led light pod, 6 inch led light bar, 10 inch led light bar, 20 inch led light bar, 24 inch led light bar, 30 inch led light bar, 36 inch led light bar, 40 inch led light bar, 50 inch led light bar.
Shape
Light bars can be round, rectangular or square. Round ones are able to fit more LEDs in a smaller area and may complement your vehicle’s design better than square lights.
Beam Angle
As discussed previously, the beam angle dictates the width and depth of the area of illumination. For driving, deeper penetration is usually better and to light up work sites a wide angle works well.
Brightness
For LED light bars, brightness is expressed in lumens. Measuring lamps in watts became obsolete when different lighting technologies came to market. The lumen indicates how much human visible light a device outputs. However, some light bar makers list their lights in raw lumens, which is the theoretical maximum, instead of effective lumens, which is a true measure of light output. A rule of thumb is to convert raw lumens to effective lumens by multiplying the former by 0.8.
Efficiency
Lumens per watt, or lm/W, measures the efficiency of a single LED or an entire LED light bar. This is a good, though not perfect, indicator as to the quality of the LEDs in the light bar. Higher efficiency LEDs have a longer life and resist fading. Manufacturers can fudge this number by measuring lumens at a voltage lower than the normal 13.8 VDC found in most vehicles.
LED Color Temperature
Correlated Color Temperature, or CCT, specifies where a lamp’s output falls in the visible light spectrum. The unit of measurement is on the Kelvin temperature scale. Thus, a particular lamp’s temperature is a number followed by a K, such as 5000K.
Cooler light temperatures are at the red end of the spectrum but are perceived by humans as “warm,” whereas higher temperatures are seen as “cool.” LEDs can produce light all over this scale, from about 1000K to 9000K, but only a small range is useful for an LED light bar.
Since the sun on a clear day produces light in the range of 5000K to 5400K, that range is excellent for night driving because human eyes evolved to work well in that range. Above that, around 6000K, the light may appear brighter, but your eyes work harder to recognize terrain, which induces eye fatigue. However, LEDs running at higher CCT are more energy efficient than at lower color temperatures.
Color temperatures in the yellow part of the spectrum are ideal for fog lights because of significantly reduced backscatter from the water droplets. Other temperatures that produce blue, amber, red or green are important for LED lights being used for alert signals.
Water and Dust Resistance
Manufacturers have adopted an IEC standard known as the IP Code, where IP stands for Ingress Protection. Good LED light bars carry an IP rating to indicate resistance to dust and water entering the light.
All you need to be concerned with regarding IP ratings are two numbers. The first, on a scale of 0 to 6, indicates the light bar’s resistance to dust penetration and the second number indicates resistance to water intrusion on a scale of 0 to 8, plus a special 9K rating. You see these numbers preceded by “IP.” For example, a light bar may have a rating of IP67, meaning it is completely sealed against dust and can stand immersion in one meter of water for 30 minutes.
These are typical IP ratings found on LED light bars:
  • IP65 – dust tight and protected against water projected from a nozzle
  • IP66 – dust tight and protected against heavy seas or powerful jets of water
  • IP67 – dust tight and protected against immersion
  • IP68 – dust tight and protected against continuous submersion in water
  • IP69K – dust tight and protected against high temperature, close-range, high pressure spray
Electrical Connectors
Two types of waterproof connectors are used on quality LED light bars, which are referred to as ATP or DT connectors. Both types are made from thermoplastic and have IP ratings of IP67 or above. They operate within a wide temperature range and use corrosion resistant contacts and silicone seals. They accommodate several wire sizes.
Light Bar Operating Voltage
Most, not all, LED light bars are made to run within the 13.8 DC voltage supplied by most cars or trucks without modification to the light bar or your vehicle’s electrical system.
For instance, it is common to see “9–30 VDC” or “10-70 VDC” as the bar’s input voltage range. These mean that you can operate the LEDs in a 12V, 24V or 48V system as long as that voltage falls within the specified range for the light bar.
LED Drivers
Do not get the idea that if you apply more voltage that the LEDs should give off more light. The amount of light an LED gives off is determined by current, not voltage. The current at each LED is maintained within a narrow range by a device known as an LED Driver.
Without an LED driver, your light bar’s color temperature and brightness would vary considerably. Sometimes, you see in LED light bar reviews owners who apply higher voltage to brighten their lights. Unfortunately, this is an indication that cheap LED drivers were used and this will shorten light bar lifespan.
PWM Drivers
The most sophisticated LED light bars have LED drivers that use Pulse Width Modulation to control LED current. There are also available external PWM units that effectively do the same thing for LED light bars without built-in PWM.
A PWM adjusts the energy frequency applied to the LED. It turns the LED off and on at a high, controlled rate within milliseconds. The rate is well above what the human eye can detect, so there is no flickering effect. This technology offers several benefits:
  • LEDs do not overheat even at 100 percent capacity.
  • LED lifespan is increased.
  • With an external control, you can dim or strobe the light bar.
  • Amperage draw is reduced overall
  • It adds protection against voltage spikes from vehicle electrical systems.
Other Features
There are additional features you should keep in mind when evaluating LED light bar products:
  • Warranty – Warranty length and terms help you gauge the confidence a manufacturer has in their product.
  • LED Arrangement – LEDs may be arranged with a single, double or quad row pattern. Multi-row bars often have both spot and flood function.
  • Wiring Harness – The best LED light bar comes with a wiring harness that includes cables, fuse holder, one or more switches and a relay.
  • Multiple Circuits – Some light bars separately switch banks of LEDs for spot or flood. They may include amber, red or blue LEDs on a separate circuit.
  • Color Lenses – Snap-on colored lenses change the light bar’s color.
  • Multi-position Brackets – Some light bars come with optional brackets or a system of brackets that clamp to channels on the light bar housing.
How to Distinguish a Quality LED Light Bar from Cheap Ones
With so many manufacturers of LED light bars, evaluating your options can be confusing. Hopefully, through reading this guide, you will come to understand the various electronic, mechanical and operating features common to most light bars. The next question is how to determine which LED light bars will give you the best service over their lifetime.
The following characteristics may be difficult to discern if you cannot physically handle a light bar, but often LED light bar reviews from owners can help determine them:
  • The number one enemy of LEDs is heat. A quality light bar will have oversize heat sinks and tight current control.
  • If possible, check the operation of a light bar you are considering under different voltage inputs. If the LEDs brighten noticeably as voltage rises, this is a sign of poor LED drivers.
  • Look closely at mounting points and brackets. The best LED light bar has sturdy, corrosion-proof mounting hardware and provide options for mounting the bar in different locations.
  • Check the IP rating. At a minimum, it must be IP65. IP69K is the highest rating, but few light bars achieve that. Make sure the electrical connectors are IP-rated.
  • A wide product line from 3″ light pods up to 50″ bars and plenty of accessories are signs of a quality light bar manufacturer.
  • Most importantly, check the warranty. Top LED light bar makers back their products with lifetime or near-lifetime guarantees. Be sure to check the fine print for exclusions.
Who Makes the Best LED Light Bars?
That is a question without a definitive answer due to the multitude of customer preferences for specific price points, features and applications. This guide has selected seven well-known makers of quality LED light bars to help you decide who makes the best LED product for you.
Black Oak LED is challenging the status quo in the high-end LED light bar industry to the benefit of consumers. They are proving to everyone that building a top quality, durable, reliable LED light bar with exceptional performance can be done without charging sky-high prices.
Product Features
The designs, materials and components that go into their products meet or exceed anything the competition offers:
  • Top-bin, 50,000-hour OSRAM and CREE LEDs
  • Oversized, integrated aluminum heat sinks
  • Quality, tight-spec LED driver circuitry
  • Torture-proof anodized housings
  • Shatterproof polycarbonate lenses
  • Custom neoprene case seals
  • The highest IEC 60529 international standard intrusion rating: IP69K
  • U.S. Military-standard housing breathers
  • Three beam patterns: Spot, Flood or Combo
  • Full IP69K wiring harnesses and stainless steel mounting hardware
  • 30-day cash-back guarantee and lifetime limited warranty
Black Oak’s high standards in build and performance come at prices half what competitors charge for equivalent products.
Black Oak LED Product Lines
Black Oak produces four main product lines:
  • Single-Row – Black Oak’s S-Series features a stealth 2-inch profile and powerful 5W OSRAM LEDs. There are six S-Series lengths from 6 to 50 inches with one LED per inch. Raw lumens output is from 3,300L to solar-bright 27,500L and power from 20W to 250W.
  • Double-Row D-Series – Black Oak’s most popular line, the D-Series features two stacked rows of ultra-bright 5W OSRAM LEDs in a 3.3-inch housing. Seven sizes range from four inches up to 50 inches with luminosities of 4,400L to a blazing 55,000L and power ratings from 40W to 500W. Curved and Marine-grade D-Series light bars are available also.
  • Pods – Black Oak’s compact LED pod lights are four LEDs in a 2×2 pattern encased in a rugged, IP69K, swivel-mount, 3.25×3.23-inch housing. Buyers have a choice of either 5W OSRAM LEDs or super-bright 10W CREE XM-L2 LEDs. Two beam optics are available: High Throw Spot or Wide Flood Optics.
  • Rounds – Available in 7-inch and 5-inch diameters, Black Oak’s Round LED Light Bars blend spot and flood optics for the ideal blend of long throw and wide coverage. The larger and smaller round light bars feature 32 or 21 OSRAM LEDs, respectively. Buyers can choose either 3W or 5W LEDs. Luminosities with 5W LEDs are 17,600L and 11,550L for the larger and smaller rounds, respectively.
Every Black Oak lighting product comes with a turnkey, IP69K wiring harness that includes cable, relay, fuse and switch. No other maker of LED light bars makes a better product at the value prices that Black Oak offers. Most products receive a further 15 percent discount for military, police and fire organizations.
Buy Black Oak LED Light Bars Here
Rigid Industries
Rigid Industries began producing LED light bars in 2006 and have since become an industry leader with top-rated lighting products made in the USA at their Arizona plant. Their lights are well-rated among off-road enthusiasts. With their acquisition by Penske, they have entered the heavy-duty equipment and commercial vehicle market segments as well.
The features embodied in Rigid products are what they call “The Rigid Difference:”
  • 120 raw lumens per watt LEDs with 50,000 hour lifespans
  • 97 percent efficient LED drivers
  • Oversize, integrated housing heat sinks
  • Redundant, multi-section circuit board design
  • Patented Hybrid, Specter and Hyperspot optics technology
  • Polycarbonate lenses
  • Molded silicone lens seals
Rigid produces 13 product lines including courtesy lights, scene lighting products and vehicle light bars.
  • E-Series – This is Rigid’s original LED light bar designed to project long-distance beams. Included in this category are their E2 and M-Series marine LED light bars in lengths from four inches to 50 inches. E-Series lights come in spot, flood or combo patterns, whereas E2 lights utilize Hyperspot and Specter lighting configurations.
  • D-Series – These are versatile 2×2 or 2×3 LED light pods with a variety of mounting options. The D2-Wide pod with amber LEDs makes an excellent fog light.
  • Dually X-Series – Duallys are the successors of the D-Series with more and brighter LEDs. The Dually XL Flood features a 3×3 LED array that outputs 2,736 raw lumens of driving light.
Rigid also offers Hi/Lo function light bars, infrared lights and dual color light bars in their ever-expanding catalog.
Buy Rigid Industries LED Light Bars Here
Vision X
Vision X LED light bar products are produced in two locations. Design and engineering takes place in the USA, while manufacturing is done at their Asian headquarters. They have built a reputation for the high-quality lights that have been tested by NASA and are in use by military organizations due to their uncompromising solutions. They also make HID and halogen lighting products.
Vision X produces 15 product lines that cover applications from camera lighting to industrial panel lighting. Their vehicle LED light bars have several advanced features:
  • High-power, top-bin LEDs with 50,000 hour lifespans
  • Pulse-width modulation for precise LED current control and dimming capability
  • Integrated thermal management of LED heat
  • Seamless spot or flood beams via custom optics
  • IP68-rated housings
In the vehicle LED light bar segment, Vision X has two main light bar lines:
  • Xmitter Prime LED Light Bar – This is a dual-row light bar using 3W LEDs housed in an extruded 6061 aluminum housing with shatterproof polycarbonate lens. It comes in lengths of five inches to 43 inches and features bottom stud mounts. Beam options are 10-degree Spot or 40-degree Flood.
  • Evo Prime Single Stack LED Bar – In lengths from five inches to 51 inches, Vision X’s new Evo light bars feature a single-row of night-crushing, top-bin 10W LEDs, each of which output 1,079 raw lumens of 6000K light. Available beam patterns are 20-degree Spot or 40-degree Flood.
Vision X also sells a single 90W LED round Cannon light that projects a focused beam over 3,000 feet forward.
Buy Vision X LED Light Bars Here
Baja Designs
Based in San Marcos, CA, Baja Designs has made a name for itself as the “scientists of lighting.” Their HID and LED lights are used on the majority of Baja 1000 winners year after year.
Their light bars use copper backing to wick away LED heat and a U-swap system so drivers can customize optics to suit driving conditions. Their lights are also used in military, industrial and agricultural markets.
Pros
  • 75-90 percent USA components
  • 100 percent USA engineering
  • O-ring seals
  • OnX LED lights that rival HID lighting distance
Cons
  • Dealer buying only
  • Prices not for the budget-minded
Buy Baja Designs LED Light Bars Here
KC HiLiTES Light Bars
KC HiLiTES has been offering high-performance lighting for off-road vehicles since 1974 and are one of the better known brands for halogen, HID and LED lighting.
They operate out of California and offer a full-range of light bar sizes including many made specifically for Jeeps.
Pros
  • Over 40 years of developing innovative off-road lights
  • Rugged housings and coatings
  • Unique 23-year warranty
  • Order online direct or via authorized online distributors
Cons
  • Smaller catalog of LED off-road lights than other large manufacturers
Buy KC HiLiTES LED Light Bars Here
Lazer Star Lights
Lazer Star Lights is a division of Weekend Concepts, Inc. They have made LED light bars since 1992 for automotive and power sports enthusiasts.
Their products are used in marine, UTV, motorcycle and construction applications too. Their LX LED line of light bars are manufactured in their Paso Robles, CA plant. Each light product line is named after a Space Shuttle: Atlantis, Endeavor and Enterprise.
Pros
  • Made in USA
  • Unique end caps that facilitate side, vertical and horizontal mounting
  • 3 and 10-watt CREE LEDs
  • Discovery line offers at-factory customizations
Cons
  • No direct online ordering
Cosmoblaze
Cosmoblaze is an Australian light manufacturer and distributor that develops extremely tough LED light bars. They are one of two manufacturers reviewed here who have lights that achieve IP69K.
Pros
  • Designs use input from champion 4WD enthusiasts and industry specialists
  • Oversize heat sinks on all products
  • Silicone gel specially designed by Dow Corning for lighting systems
  • 5-year warranty
Cons
  • Only 5 years on the market
  • Must order from Australian distributor or on eBay
Federal Signal Light Bars
For more than 50 years, Federal Signal has been in the business of offering comprehensive lighting and alert solutions for emergency and work vehicles. Two of their most innovative technology solutions are in reflector design and an 85 percent reduction in connection failure points in light bars. Read our popular Federal Signal LED Light review!
Pros
  • Decades of technology leadership in EMS lighting
Cons
  • Limited selection of work lights, no long light bars that are non-emergency use
Sylvania Light Bars
Founded in 1901, Osram Sylvania, Inc, together with OSRAM AG, is the world leader in automotive lighting for original equipment manufacturers (OEMs) and the aftermarket. The company’s global automotive lighting division has its principal North American operations in Hillsboro, N.H. More than 400 lamp types are produced for cars, trucks, and electronics in facilities throughout the U.S., Europe, and Asia.
Buy Sylvania LED Light Bars Here
Buy Sylvania LED Light Cubes Here
Tips on Choosing the Best LED Light Bar
Obviously, LED light bars are not created equally. Their differences include available options, brightness, light color, beam width, heat management and mounting technology, just to name a few. To reduce potential confusion, start with determining your specific light bar needs.
How Much Light Do You Need?
Most 20″ LED light bars provide more than enough light for good or inclement weather when driving on paved roads. Consider starting with a couple of low-mounted 4″ or 6″ flood light bars, which will dramatically increase road visibility. If you do a lot of off-road night driving, then larger light bars, up to 50 inches, are useful.
Mounting Options
On most cars, your mounting options are somewhat limited, so low-profile light bars make sense especially for grill mounting. Trucks can mount light bars on the roof, rack, hood or grill, so size and profile are less important.
Judging Quality
It is true that you could buy 2 or more less expensive light bars for the price of a quality one. However, do you really want to risk light bar failure when you need it the most? Reliability and performance come at a cost.
That said, you can make a rough assessment of a manufacturer’s or distributor’s product quality by looking at three things:
  • Length of warranty and warranty terms
  • The breadth of their product line including accessories
  • Reviews from people who actually use their products
Reactions: Johnny P
One note about "CREE" led's - CREE makes MANY MANY different models of led chips, so when you see "CREE leds" or "CREE lightbar", that info is pretty much useless and they are just trying to use the CREE name as a marketing tool... Even if they say 3 watt CREE leds, that's a little better, but still not specific enough. There are different generations of chips with differences in efficiency (Brightness per watt or heat generated).
Pretty much all of the cheap Chinese light manufacturers will overstate their brightness ratings, and while they will still be pretty bright, you can't rely on their stated lumen rating as a comparison tool - just assume it is lower than what they say...
I haven't looked lately to see if anyone actually does it, but unless the manufacturers tell you the exact chip they are using (XP-G, XP-G2, XM-L, etc), and the current running through each chip, just saying it uses CREE is pretty meaningless. If anyone runs across a lightbar using XM-L or XM-L2 chips, let me know and I would love to have one with those - they are VERY bright/efficient for the cost and can be driven at 10 watts each in the right setup.
If anyone has any technical questions about led chips, feel free to ask - I've been into the nitty gritty of them for 10 years in dealing with superbright led flashlights.
Couldn't have said it better myself!
I might add that I personally would never run a light bar. I think they look ugly as sin and plain wrong on a TJ.
I will add to that however that I totally respect that everyone has their own opinions. If you want to run a light bar, then by all means, run one! It's your TJ, not mine!
I'm simply saying that I think they look like garbage on TJs.
Lots of good info. I am a police officer and will be adding a white lightbar on the hood but I also wanted to be able to show red/blue in case of emergency. Not to pull anybody over but to identify the vehicle in the event of emergency.
Do you know of any lightbars that will also switch to red/blue? I've found a few that will do white and flashing amber and operate exactly as I'd like. I can't see any that will do the red/blue.
I haven’t seen any light bars that do red and blue. You may need to get some separate LED lights for that.
Thanks for this write-up as it was very insightful.
However, I am looking for some advice. I recently bought a new front bumper in order to get something capable of holding a winch while also providing D-ring mounts and settled on the EAG one shown below. One of the perks of this bumper was that it came with two mounts for lights at the top.
I don't do much, if any, off-roading at night, but it would be nice to have some additional lighting, primarily as a just-in-case option. Because of this, I'm wondering if it would be so bad to get something really cheap off of Amazon, such as these (https://www.amazon.com/dp/B00IY3YLCI/?tag=wranglerorg-20) for about $15.
As much as I like the suggestions above, I don't see much available for less than $100 and even if I could get a pair for that price, it would still be a lot more than the paltry $15 range that several lights on Amazon are listed for. I figure even if these things crap out on me, I could still replace them several times over before I get close to the price range of more reputable options.
I would much rather spend my Jeep budget on more important upgrades than lighting, but would a quick $15 here for cheap stuff be reasonable?
I
I View attachment 47145
The cheap ones crap out usually within a year. I've read about this time-and-time again all over the internet and in the product reviews. The other thing is that the cheap ones aren't waterproof resistant (though they claim they are), so if you live somewhere where it rains a lot (or you park your TJ outside), you won't be in good shape.
However, for the price of $15, you could indeed replace it a number of times if it were to break.
The main problem is not them crapping out on you quickly (which they will), the main issue is the light they give off is down right horrible. They offer no increased distance than your low beams, and just scatter light everywhere. Waste of time and money. If you want passable leds and at reasonable price, than the best you can do is rough country or lights from oz-usa.com. Don't waste your time with cheap chinese leds from Amazon.
I'm trying to find info on any of the classic style light bars. A mount that props up 4 to 5 round lights but I'm finding very little available info anywhere. Is there a guide for those that maybe i missed?
No, but I believe KC makes them.
Anybody got any updated lists of solid budget branded light bars?
1) I'd like to add a couple to my rack, mostly for camp duty, but 1 in the rear for backing up and I think I want to put one up top on my rack facing forward, because when I'm driving through high brush my headlights get covered. I have a bar on the hood, but I'd prefer something a bit better and I would assume higher would be more useful. I don't think much more than a 20" low profile type bar would be needed for forward aux lights, but I'll take any suggestions.
2) But mainly I have a bunch of bush hogging I have to get done soon and I think 1 of the small tractors finally is running mostly correct and I will need to run a few lights for working at night. I'm still playing with mounting locations but I'd like probably 4 small light bars (1 pointing to the rear or and 2 or 3 forward). This will look stupid, but looks have nothing to do with my decision for these. However I don't necessarily want complete crap as I may use them for random future projects.
https://www.amazon.com/gp/product/B01D0FS5TE/?tag=wranglerorg-20
I decided on this bar from OZ-USA. I saw them mentioned above as being reputable. I'll probably grab something else to compare it to, but I haven't decided yet.
I do have an old and cheap bar that has faded, but worked as of last year. I don't use lights all that often, but when you need them, they're certainly handy. But for occasional use it's hard to justify some of these price tags.
@Attomic-tj personal preference but I think straight looks better than curved because of our very flat windshield and the square-ness of the top. Just make sure whatever length bar you get, 50" or 52" to get corresponding brackets for that length.
Tip: Use a ratchet strap to pull the brackets in closer together.
-When installing a light bar with windshield brackets by yourself it can be difficult to mount the light to the brackets because you can't be on both sides at once and standing on the hood isn't a good idea. Use a ratchet strap attached at the very top of each bracket to pull them closer together.
-Use a zip tie temporarily to hold the light up to one of the brackets, side A
-Install the screw on side B (opposite side)
-Come back to side A, cut zip tie and install the screw
-Remove ratchet strap
Not much mentioned in this thread about budget brands so I'll share my experience:
Yitamotor 52" light bar with brackets $86 on Amazon
They sent me a kit for a JK, returned it and they sent me the correct one but that process took about 3 weeks
Wiring is super easy and seems legit with inline fuse and switch relay. Connect to the wiring to the light and the battery and you're done. Plenty of length of wire was provided.
No logos which I happen to like
IP67 and so far no issues
Lifetime warranty (I rather not need to test that claim from a budget brand)
I will eventually get some sort of cover for the lens since it looks very bling-y compared to a single-row light bar but so far no whistling
I got the straight one. Looks to me wasn't as important as functionality. If curved provides better coverage I'd get that. But I got a hybrid spot and flood bar. Covers pretty well. Only issue now, is I'm getting a ton more wind noise on top between windshield and hard top. Not sure if the bar crates that much drag or weatherstripping on hard top is going bad and letting in more noise.
Any one have this issue? Maybe the cheap Amazon bracket is putting the bar up too high and if I lower it to even out with top of windshield that will fix it?
I have not personally heard any whistle on mine but there may be a slight increase in wind noise by or maybe I just haven't turned my radio up as loud lately...
My brackets don't allow for different mounting heights but in many YT videos suggest the following treatments:
-slightly angled the light up or down to deflect that wind noise but ideally you want to keep it aimed properly just like you would headlights
-Weather stripping on the fins (for whistle)
-Aerolidz or similar cover
-Crank up the tunes and ignore it like all the other noises in our Jeeps
