What a cluster...whatever you call it.
I finally figured out the front windshield header. They made it not to fit in the stock channel in the windshield header. But it wraps around the entire header and then clamps down. Bypassing the actual stock channel in the header altogether. AND you have to fold the plastic tab over once, and roll that under the entire header, to make it fit right.
But now it's so cold (probably upper 50's low 60's. It says to install in 70F or better.) I have a 2-3 inch gap on one side at the base of the window. And the rear window won't zip in past one third of the way. Basically to the first corner. And the door uppers won't go on at all. I need another 2 inches to get those on. So I put the upper windows on the front seats, zipped everything up as much as possible. And turned the heat on high. HAve a timer set for 45 minutes. Maybe that will do the trick. But the back window is halfway open. F me. lol.
Lastly, they did not say you needed those wide black things that go around the back half of the front windows. I don't know what they are called. But now I have this gap between the soft top and the back of the front upper doors. Those are my old door uppers as I'm trying to keep the heat in while I try heating up the top from the inside so I can get it to go on all the way.
What are these called? I need a pair. And what year range will fit my '99 TJ? And how much do they run used?
The directions from Rampage (Lund) suck. It shows you having to screw the soft top into the windshield header. Which don't exist on my older stock header. And then when I called and talked to their tech. She had no clue that you had to double over the plastic on the front of the soft top and wrap the top around the entire header instead of just putting it in the channel in the header like it does stock. It is a better fit IMHO. But it would be nice if anyone at Rampage knew this. She actually said "sometimes they fit but sometimes they don't. Because we have these made overseas.".
Further it doesn't say you need those things above. Again I use the term cluster...whatever you call it.
I found some local but have no idea how much they are worth or what years fit my '99.
