Shop pressure tested cooling system at idle after replacing the radiator for the second time in a month(free) supposedly due to poor quality Murray rads which is my mistake for not getting a oem
No coolant in oil
Brand new Mopar rad cap
Ive had a couple shops here in Yuma look at it and neither “thinks” it’s a head gasket but neither shop has impressed me with their competence. For example I had a shop replace the radiator and flush out the blue coolant from engine and replace with G05 I supplied and now I have green coolant because they didn’t flush the engine good.
It seems to spray out the reservoir when rpm’s get higher like when accelerating onto highway.
I personally think it’s a small leak in head gasket
My G-05 looks like dehydrated piss (darkish yellow). Maybe the shop didn't drain the block. If you have leftover coolant you can compare the color to what's in your reservoir.
Have you done a compression test? That's the first thing I do on a vehicle if I don't have it tested before I purchase a vehicle. I'd also check the spark plugs for any indication of coolant (might not show yet but worth looking).
Edit: when mine leaked from the reservoir lid and the fan sprayed it all over, there was a distinct line of coolant splatter on the inside of the hood. Are you overheating?
