Trim the lower, rear spring perch for more shock clearance. Eliminates the need for a shock mount relocation bracket.
What exactly is the Reverse Parking brake project or Mod?
- Move the rear upper spring perch
- Rear axle shock mounts so the shock body clears the axle and perch
- Remove small bits of hangy downy things. You’ll see them.
- Trim the front lower shock mount so the lower control arm has plenty of space at full droop
- Tie rod flip
- Reverse parking brake
I thought most people trimmed the spring perch rather than actually moving the shock mount unless you outboard?
I had to trim and use extensions on my rig. Trimming alone wasn’t enough with a can down shock and 4.25” lift with pinion at ~23*.
On my sons we trimmed and again, it wasn’t quite enough. We’re cutting his stock brackets off and welding on different in a better position.
What’s the general consensus for doing the tie rod flip Insert on the knuckle? Just buy an insert? What’s the best to get one? Or send it to Blaine?
