A few weeks ago I had a crank/no start (and then intermittent stalling) issue that I resolved by replacing the TPS and cleaning up some ground leads. I wasn't quite certain I was out of the woods yet, but it drove fine for a couple of weeks. Today it just stalled twice at intersections around town. It sounds like its running kind of rough, possibly missing, but no codes for that or indicators. I pulled P0123 (TPS High Voltage) and P1391 (Intermittent CMP or CKP) from the OBD right after. Tested the TPS and the sweep voltage is good, doesn't appear to be any issues — except here's where things get weird.
I pushed down on a conduit (around S-127) and noticed the signal voltage coming from the TPS dropped to 0 on my multimeter whenever I did it (red to signal wire, black to battery ground). Sounds like a short, but when I turned the key off and tested the resistance it went from what I would assume is normal (0.966kΩ) to 0L, or no connection. When I started it up, it ran ok, but when I started pushing down on the wire it seemed like it was missing again (but no new codes). Also one of the times I started it up, I forgot to plug the TPS in and it seemed to be running fine, when I plugged it in it started and idled rough. (even though I verified the TPS was working.
When I tore off all the conduit and electrical tape around, I noticed that a bunch of the sensor ground wires were bunched up, and then all converged on one splice in the wire, and then went back to being their own individual wires. After taking the conduit off, I haven't been able to recreate the dropped connection yet.
I haven't tested the CKP or CMP yet (mostly because I don't know how), but I did verify that they're getting 5v supply and have a good connection to ground that isn't affected by me wiggling the wires around.
I don't really have much mechanical experience at all, but any suggestions on things I could do with basic tools would be really helpful.
Here are some pictures of what I mean by the voltage dropping, I'll upload more tomorrow of the wires and all that.
