Or the throttle cable from your neighbor's new push mower!
When building your own. What length of cable do you recommend? I am guessing 6'.
Dumb question: are these levers spring loaded, or does it stay at a specific speed if you take your hand off?
(I'm not sure if I'm phrasing that correctly.)
Not spring loaded. The lever throttle kits you buy should all be using friction shifters. They will hold their position.
I think it was about 6'. I bought cable from walmart and needed every bit of cable and casing from the longest set in the package.When building your own. What length of cable do you recommend? I am guessing 6'.
So in other words, it's an extremely low speed cruise control?
There is a tension knob so it can be either. It can stay where you leave it if you have the tension tight or the throttle body return spring will pull it if you have the adjustable tension light. I always leave mine light in case of accidental bump but can tighten the tension for it to stay where I leave it if desired.Dumb question: are these levers spring loaded, or does it stay at a specific speed if you take your hand off?
You could do it to an automatic.Is this a manual shift only mod?
