The max life is synthetic .
The Castrol Edge is not
I don't need synthetic do I?
Going with a synthetic is a good decision if your local conditions are uber-cold, like below zero. Synthetic is proven to flow better during cold starts which is a reason to run it. But for non-uber cold conditions, a modern conventional motor oil like Valvoline, Castrol, Mobil, etc. is fine for all other conditions. I have run nothing but a conventional motor oil for over 50 years of driving and I have never had an engine failure. I ran synthetics in two Lexuses and one BMW for warranty reasons but once their warranties ran out, switched them both to conventional Valvoline motor oils years ago.Should I use synthetic?
Ok thanksGoing with a synthetic is a good decision if your local conditions are uber-cold, like below zero. Synthetic is proven to flow better during cold starts which is a reason to run it. But for non-uber cold conditions, a modern conventional motor oil like Valvoline, Castrol, Mobil, etc. is fine for all other conditions. I have run nothing but a conventional motor oil for over 50 years of driving and I have never had an engine failure. I ran synthetics in two Lexuses and one BMW for warranty reasons but once their warranties ran out, switched them both to conventional Valvoline motor oils years ago.
And going to a synthetic will not cure or help engine ticking. Synthetic motor oils are not all that much different from modern conventional motor oils.
I'm still not sold on any of those additives. If it were my Jeep and I was having ticking and didn't know when the last oil changes was. I would change my oil using a good quality oil and filter. Start there and you will never go wrong.Ok I'm at the parts store and looking at
ZMax
LUCAS
MARVEL mystery oil
What would be the best for the ticking
ZMax
LUCAS
MARVEL mystery oil
X2The manifold and valve cover are close enough together to fool the ear but the sound produced are a little different imo.
I've had several engines that had lifter ticking when cold then subside when warmed up.
You may well have an manifold leak.
Have someone hold a rag over the tailpipe while you listen up front.
But as suggested, change the oil to see if that may be the culprit.
Nope. Dino oil is just fine in the TJ.The max life is synthetic .
