History:
2004 LJ - OME 2" lift, 1.25" JKS body lift, JKS upper/lower control arms, track bars and sway bar links, all of which are completely adjustable.
The Jeep is in the shop for an alignment and wheel balance. This is a performance shop that deals with 4x4 off road vehicles as well as track cars.
I have Level 8 Tracker 15x8 aluminum wheels with 33x10.5x15" KO2 tires on the Jeep with enough wheel weights on them to sink the Titanic. I mentioned that I am getting a vibration at 65 mph. They said we like to static balance larger off road tires. I did a little research on the forum and it appears that is the way to go.
They also stated that instead of setting toe to be slightly in they have found that setting the toe slightly out, around 1mil, is much better. They found that this keeps the Jeep from being "darty" when cutting the wheel, especially at higher speeds. It sounds logical... is it?
Suspension question:
The lift and all of it's components have been on the Jeep for about 6k miles. I was telling them I was hearing clunking coming from underneath and they confirmed that many of the parts were loose. They explained to me that, while I have a fully adjustable suspension which is a really nice setup for off roading, the components will tend to loosen as a daily driver from normal road and highway driving. In essence he said throw a wrench on the components during your oil change; we will show you which ones to keep an eye on. I believe he mentioned the huge 2" nut that is on the adjustable part of the lower control arm. He also noted that there will be a very slight "clunk" noise coming from the rear control arms because the JKS arms have a ball at the end of them. As that ball loosens up after breaking in it introduces play that is inherent to the design. He said he can show me a bad JKS arm and a good one to better explain.
On the surface it seems weird that I should have to keep an eye on suspension components but then again I'm a noob and these guys are extremely knowledgeable and also have their own Jeeps that are all set to off road.
