- Joined
- Apr 9, 2016
- Messages
- 70
Wondering about installing TPMS on my '04 Wrangler Toad. Any pros & cons and recommendations will be appreciated.
Chief
Chief
I think the question I have is why? Is it just something you want to install because you can, or do you worry about low pressure in your tires often? I hear nothing but issues with it on the new JKs, especially when off-roading and airing down.
Mostly because while being pulled behind the RV, I could have a low or flat tire for a long time before I knew I had a problem. If I had a monitor in the coach I could at least see that I have problem before I run the wheels off it. I always to a "walk around" when I stop for fuel, but that could be a couple hundred miles or couple of hours.
Chief
Sounds useful. If you find someone on here with advice on TPMS for a towed vehicle that can be monitored from an RV, it'll be a first for me. Never heard of that, but I don't tow, so what do I know...
Live and learn.It’s very common in the RV world to use a TPMS monitor for your towed “toad” rig.
