I have a 2000 TJ and I bought a set of BFG Mud Terrains and rims off of a 2016 Willys. They are 255/75/17. What is the best tire pressure for street driving?
That's roughly a 32" tire so probably 29-30 psi is about right. Never go by the psi pressure molded onto a tire's sidewall, that only indicates the tire's max safe air pressure. The correct tire pressure depends on the weight of the vehicle it is supporting, the tire size, and the tire's Load Range as in C, D, or E. A Load Range C tire is appropriate for a Wrangler.I have a 2000 TJ and I bought a set of BFG Mud Terrains and rims off of a 2016 Willys. They are 255/75/17. What is the best tire pressure for street driving?
27 psi around town when lightly loaded, 29 psi when fully loaded with people or gear on the highway. For 33x12.50R15 tires it's 26 and 28 psi but the 10.5" wide version needs just a touch more air.I’m running BFG 33X10.5X15 on my 06 TJ.
What’s a good pressure?
Thanks Jerry27 psi around town when lightly loaded, 29 psi when fully loaded with people or gear on the highway. For 33x12.50R15 tires it's 26 and 28 psi but the 10.5" wide version needs just a touch more air.
What setting are your shocks at? And are they the 5-way adjustable RS9000 or 9-way RS9000XL? 24 psi is a bit light for 33's.I have Cooper A\T 33x12.5 R15's on my LJ and am struggling with the pressure and adjustable shock setting (rancho 9000) to get a comfortable ride, am trying 24 lbs. to see if that helps. Was at 26
Glad you had a good experience with John, he's one of the very best in SOCAL. Are your tires Load Range C, D, or E?Shocks are 9-way, set at 4 on the front and 3 on the rear.
Also thank you for the referral to John at All 4 Wheel, ended up having him do the gearing, and lift install.
That you're having a stiff ride with Load Range C tires with 26 psi in them and your shocks set at the settings they are is surprising. I would not go lower on the tire pressure which is as low as I'd run with those tires. Instead I would try going down a setting or two on your shocks.Load range C
Not always and not usually. Very few people know how to properly interpret the chalk test's results, most end up with often grossly under inflated tires trying to get the chalk off the entire width of the tread. Few tires are designed for 100% of the tread to touch the road surface except perhaps during hard cornering or while rock crawling..Do the chalk test and you will find the sweet spot
