Tire Size vs. Hub Height Survey
Serbonze
TJ Neophyte
1,730
1,633
Florida, USA
#41
New Cooper SST Pros
33X12.50 15
24.6 PSI
15 3/8"
Load range C
@jjvw you may want to explore how people are measuring to the center of the hub. It can be precise or it can be an eyeball, and I think with these small differences you may want it to be as precise as possible? I originally held a tape measure up to to my wheel and tried to figure out how to get an accurate measurement from the center of the hub when that center is six inches in from the wheel. I ended up using a level and doing some calculations. Maybe I'm just dumb and couldn't figure out a simple way, but originally eyeballing it with just the tape measure I guessed 16".
I think the following people have run [edit] or commented about Load Range D or E tires in the past. Not sure if they're still running them now.
Serbonze
I've changed over to load range C. I never measured the hub height when I had the Es so I can't provide any useful information besides current data for this discussion. :)
jjvw
jjvw
0-60 in 18 seconds
4,364
3,590
Colorado, USA
#42
Here is what we have so far. It isn't really enough to see anything yet. I am also unsure how to present the data.
jjvw
jjvw
0-60 in 18 seconds
4,364
3,590
Colorado, USA
#43
Blaine's method using Grimmjeeper.com beginning here...
https://wranglertjforum.com/threads/what-is-your-nominal-ride-height.16717/page-4#post-277228
...is going to be the most accurate as well as the most broadly informative beyond this discussion. Measuring the axle as described earlier is also very good. I took my first measurement with a tape measure and a level off of the hub, which was quite close to Grimmjeeper (either by luck or skill).
Likes: Serbonze
Jerry Bransford
TJ Guru
8,822
9,776
Escondido California
#44
I don't understand how it could be difficult to find the precise center of the hub. I really don't.
The center of the hub is half-way between the top & bottom of the wheel. Not around half-way, precisely half-way. I.E. 7.5" up from the bottom of a 15" wheel.
Likes: jjvw
Mr. Bills
793
1,009
Area Code 530
#46
315/75R16 (Mickey Thompson Baja ATZ P3) mounted on 16x8 wheels
Load Range E
Manufacturer's Advertised Diameter - 34.5" @ 65 psi measured on 8.5" wide wheel
Manufacturer's Advertised Tread Depth - 18.5/32"
Measured Hub Height - 15.75"
Measured Tread Depth - 14/32"
Measured PSI - 22 psi @ 37 degrees ambient temperature (tires last filled/pressure checked at 26 psi when ambient temperatures were in the 70's).
Weight of Jeep - unknown.
I hope this information helps, but my thinking is that the hub height data being collected cannot yield usable results without knowing the weight of the jeeps being measured because the loaded radius of a tire will change as the load on that tire increases. In other words, when measuring the hub heights of two jeeps with identical tires on identical rims with identical air pressure in the tires, the hub height of the jeep weighing more will be less due to the increased load on the tires.
Likes: Serbonze
toximus
1,052
756
Northern WI
#47
Load Range E
You forgot the elevation and moon phase and it's effect on gravity.
bobthetj03
vibrajeep
Load Range E
Be careful! You'll be accused of requesting Nano-measurements! :nono:
mrblaine
TJ Guru
2,972
3,247
Quail Valley, CA
#55
!5" wheels are 16" in diameter, maybe it's more difficult than you think...
A 15" wheel as in if you are measuring the hub height of a rig with that size rim. Halfway between the two edges of the rim of any size will give you the center of that rim. So, for the dimensionally impaired, you would measure the overall diameter of the rim no matter what size it is, divide that by 2 and write it down. Then you measure from the ground up to the same edge of the rim you used to measure the overall diameter. Now write that down under the first number you wrote down. Now, add those two together and write that down and put a circle around it.
When you post up your hub height, use only the number you circled.
That said, 15" wheels are not 16" in diameter or they would be called 16" wheels. The diameter of any automotive wheel we use is measured at the spot where the tire beads sit. The bead lips may measure larger than the rim diameter but that doesn't change the size of the wheel which is what size tire fits on it.
