Just looking for a clear answers on different kinds of manual transmissions that will bolt up to a 2.5l 4 cylinder 1997 Jeep tj. I currently have a 30rh automatic 3 speed transmission which I’m trying to swap for a manual transmission. I’ve read that the 5 speed ax-5 transmissions will bolt up to the 2.5l but I’m having trouble finding one to swap so I was curious to see if any other manual transmissions will bolt up to the 2.5. if so, how hard is the swap? Will I need a longer/shorter drive shaft and/or tail shaft? I’ve read that you can use the Bellhousing from a 4 cyl dodge Dakota with the ax-5 and use with the ax-15 transmissions. Anyone one every tried this? thanks in advance
UPDATE:
Really looking for answers on wether or not I can use a ax-15 transmission/transfer case and Ax-5 Bellhousing to replace my 30rh transmission in my 1997 Jeep Tj with the amc 2.5l 4 cyl. Thanks
UPDATE:
