TJ Fest 2021
TJ bounces hard on rear passenger side
ahartend
Peoria az
2003 Jeep Wrangler with a 2.5" RC lift kit, recently bouncing hard on left rear passenger side like I lost a shock or coil spring is bad??
ahartend
ahartend
Peoria az
Looking for some advice, I've had the RC 2.5" lift kit for 1.5yrs. do I have bad coil spring or has the shock gone bad. It feels like I'm riding on the coil and shock is not dampening. And no it's not a mail Jeep :cool:
CodaMan
California Prisoner (for only a while longer)
California (for now)
Sounds like you lost a shock unless the spring is missing or no longer seated.
ahartend
ahartend
Peoria az
It's all there, RC is sending me another replacement shock, it's my wife daily driver, it's for show and go, just need to get her back on the road, I weary of her driving it on the freeways, so it's just been a grocery getter for 2wks. now. Here pictures of the left side coil springs and right side, they both don't look right??
seventy1
Ann Arbor, MI
Sorry, I was referring to the "left rear passenger" description. Only RHD would have the passenger side on the left. Sounds like you might have bottomed a shock. Were jounce bumper extensions part of your lift?
seventy1
Ann Arbor, MI
The springs look intact, funny that the coils are closer together on top on one side and bottom on the other. If RC is sending out another shock, no questions asked, then it could just be a defective part and they've seen this before.
ahartend
ahartend
Peoria az
They have a 3yr warranty they say, I bought them in Nov. 2018, had them installed in Jan. 2019 so I have some time to figure out what needs replaced, I'm waiting on the shock, once I change them out then I'll know if that fixes it or not. Thanks!
04solartj
non free state north ny
yeah they look like there in opposite of each other don't they?
freedom_in_4low
Monument, Colorado
coil springs don't so much "go bad". Unless the actual spring wire just breaks (which I have seen before), their job is simply to support the weight of the Jeep at the desired ride height, so if it's doing that, it's fine.
If it's bouncing like you describe I'd say almost 100% a bad shock.
Reactions: Alex01
scottgraham
land of waterfalls
It does look like one of the springs was installed upside down.
Alex01
Enthusiast
Martinez, CA, USA
Pictures from other TJ's would help if possible, so I can fix it, Thanks
Flip the passenger side over so it looks like the driver's side. Like JJVW said though it will not have any effect on ride, just aesthetics.
ahartend
ahartend
Peoria az
Waiting on a replacement shock from RC, so I'll flip the right rear spring when it arrives, Thanks
