TJ cranks but won't start
Woodard_
3
Tolar, TX
I drive a 1999 Wrangler Sahara, went to start it the other morning and it wouldn’t. It cranks and sounds like it wants to but It won’t. I’ve replaced the Crankshaft Position Sensor as well as the Ignition Coil and still no luck. If anyone knows/ can share anything about this issue it would be greatly appreciated! Thank you!
Daryl
Bumblebee
931
California, USA
Remove your air intake tube from the throttle body. As you crank it over have someone spray a small amount of starting fluid in the throttle body. If it starts you have a fuel delivery problem. If it doesn’t start you most likely have an ignition system issue.
Reactions: Woodard_
