Hi, super new to this forum and jeeps in general. I picked one up about a week ago and noticed a wet spot on the exhaust that seems to drip from the rim of the sump on the left side of the engine/sump, would coolant leaking from the water pump/thermostat housing cause this? i thought it would leak from the front but seems to follow the crack between the sump and the engine.
mind you it doesn't over heat or get hot (100c) middle on the coolant temp mind you it could just be a minor leak which will progress so want to get it sorted.
Looking at replacing
Water pump.
Thermostat housing and the little pipe that connects to it.
Thermostat.
Just seeing if anyone else has had this before, iv search and its normally at the front.
2003 tj 4L Aus
Water pump.
Thermostat.
2003 tj 4L Aus
