What if the lean is exactly the same before and after installing new springs? It was a 1/2" before and after. New springs were same height. (not side specific) I could fix it by adding 10mm spacer on top but can't stop wondering what's off.
Assuming it hasn’t been wrecked or the frame is bent,
It would be the towers and weld work from the factory - these things aren’t assembled perfectly or even made to be - there are elongated holes and tapered bolts all over to allow for misalignment.
