First off...I’ve got to say thanks to many on the forum for the awesome info and recommendations. Because of all the things I read on here, I installed 2” OME HD springs and Rancho RS5000X shocks along with a rear track bar relocation bracket to my previously stock 2004 Rubicon. I went ahead and dropped the TC about 9/16”. There are no adjustable track bars or control arms either. I left the stock 245/75R16 tires on as well with 26psi in all 4.
I did the alignment myself. I triple checked it. I started out clamping square tubing to the discs and got the toe in set to the 1/16”-1/8” range. Then I checked it again measuring the tires...measurements came out the same. I centered the steering wheel. I took the Jeep for a spin, and it drifts left slightly. So I jacked her back up, pulled the tires off, and clamped the tubing back on the discs and remeasured. Everything checked out. After the lift, the front axle is off-center maybe 1/4” to the driver’s side.
The drift is not a hard pull, but if I let go of the steering wheel it would probably go 200’ before I’d be running off the left side of the road (of a narrow two lane road I should add). It’s not overly noticeable while holding on to the steering wheel. Everything else is perfect...no vibes at all and an amazing ride with the new shocks and coils.
I used the drag link to center the steering wheel only and the tie rod bar to adjust the toe. I did come across the factory service manual for the 2004 TJ posted on a thread here that said use the drag link to adjust the right toe and the tie rod bar to adjust the left toe. I did not do it that way.
Any suggestions would be greatly appreciated!
