TJ runs out of gas while still showing 1/4 tank
How many gallons to fill up from empty? If you have that data you can determine if there was gas still in the tank or it was truly empty. I Suspect you have a sending /float issue.
Had that problem before and it turned out that I had mud and crud built up under the gas tank and it had collapsed part of my plastic tank. Got all that out and filled the tank and it self expanded back to normal. Should be easy to look for if that is the problem.
Reactions: freedom_in_4low
