My ‘01 TJ Sport 4.0 seems to burn thru Coil Packs lately. My TJ started rough idle after start following a 20+ minute stop after warming up and NO codes. Usually it would smooth out and drive great. Cold startups were perfect. One thing of interest is the 4.0 engine runs very hot. The hood will get quite hot after a trip. However the hot start misfire issue worsened so I replaced the CP. I purchased a new one from Amazon by AA Ignition because they offered a 2 year warranty. The first on lasted about 2 months and started misfiring on restart after warmup. Finally I got a Check Engine light and a reader said the misfire was on the #3 cylinder. I contacted AA Ignition thru Amazon and after a couple rounds of texts they sent me a replacement. It’s been installed a couple of weeks. Unfortunately today the misfire started again. I believe this might be a heat related issue as the misfire only happens after a short stop after the engine fully reaches operating temp.
As an aside, I’ve even considered adding vents to the Hood.
What’s the collective wisdom.
