99 has distributor and coil on the Passenger side of the engine. Start there, as said above pop the distributor cap off and see if there is moisture in the cap. If no moisture, check to see if you have spark at one of the plugs, if not then test your coil to see if the coil is bad or if is the distributor. You can test the coil with a multimeter. If you have spark and coil is good, then check fuel pressure (but if it quit working after you sprayed water in the engine compartment, it is probably electrical). Then if you have spark and you have fuel pressure, start disconnecting all the sensors, TPS, CPS, etc.. and see if there is any water present.
