Chili Pepper is back together and refuses to fire up, so it's time to put it out there. During the process the engine remained assembled except for a cleaning and restoration of accessories. At this point the pump primes properly and fuel pressure is good (intake manifold is wet) and she cranks with authority. When I set her on TDC and insert the distributor there is no attempt to fire with or without starting fluid but when I re-install the distributor 180 deg out she does attempt to fire. I set TDC with a vacuum/pressure gage on cylinder # 1 and when I pass TDC it goes into vacuum on the intake stroke with a half rotation then pressures up on the compression stroke. Distributor seats properly with the alignment lock down tab properly positioned over the bolt hole. I locked the rotor in the proper position with the alignment hole during the installation and the rotor is close to the #1 post on the cap.
Just pulled plug #2 and it is showing what I would consider a healthy spark.
She was running fine prior to the frame swap, I replaced the plug wires and coil with a new NTK coil as the original had internal rust expansion and numerous cracks. I have swapped all the old stuff back in with similar results.
My thinking keeps coming back to timing but at this point I'm hitting a mental wall, what am I missing here.
