Getting ready to get motor in the Jeep. What headers did you use with the Dodge Magnum swap?
Yes @Paul Ruggles it would have been easier with drive shaft & exhaust manifold routing.
If your V8 is a 5.2 or a stock 5.9L engine making advertised power, the much more common 44RE from a 1996-1998 5.2L V8 ZJ Grand will probably be alright behind it long term if the driver isn't overly abusive and there are upgrades that can be done to clutch packs and hard parts to make it almost as strong as the 46RE. So if anyone is still contemplating the swap, a 44RE by a reputable shop reman'd would probably hold up unless you plan to be really hard on it or tow a big heavy trailer which isn't really a good idea with the short wheelbase TJ to begin with.
RR
