Top Fuel dragster acceleration put into perspective
Bighammer
Oregon Coast
TOP FUEL ACCELERATION PUT INTO PERSPECTIVE
Check this out guys. Amazing to say the least…
Top Fuel dragsters are the quickest accelerating racing cars in the world and the fastest sanctioned category of drag racing, with the fastest competitors reaching speeds of 335 miles per hour (539 km/h) and finishing the 1,000 foot (305 m) runs in 3.64 seconds. Here are some fuel facts.
* One Top Fuel dragster 500 cubic-inch Hemi engine makes more horsepower (11,000 HP) than the first 4 rows at the Daytona 500.
* Under full throttle, a dragster engine consumes 11.2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
* Dragsters reach over 300 MPH before you have completed reading this sentence.
* In order to exceed 300 MPH in 4 seconds, dragsters must accelerate an average of over 4 G's. In order to reach 200 MPH well before half-track, the launch acce leration approaches 8 G's.
* Top Fuel engines turn approximately 480 revolutions from light to light!
* Including the burnout, the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid off, the crew worked for free, & for once, NOTHING BLOWS UP, each run costs an estimated $1,000 per second.
0 to 100 MPH in .8 seconds (the first 60 feet of the run)
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
6 g-forces at the starting line (nothing accelerates faster on land)
6 negative g-forces upon deployment of twin ‘chutes at 300 MPH An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on earth . . quicker than a jet fighter plane . . . quicker than the space shuttle.
The current Top Fuel dragster elapsed time record is 3,628 seconds for the 1000' track (2018, Clay Millican). The top speed record is 336.57 MPH as measured over the last 66' of the run (2018, Tony Schumacher).
Putting this all into perspective:
You are driving the average $140,000 Lingenfelter twin-turbo powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged & ready to launch down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH. The 'tree' goes green for both of you at that moment.
The dragster launches & starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums & within 3 seconds the dragster catches & passes you.
He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it - from a standing start, the dragster had spotted you 200 MPH & not only cau ght, but nearly blasted you off the road when he passed you within a mere 1000 foot long race!
That's acceleration!
Spent a lot of time at New York National Speedway and Englishtown back in the late 60's and thru the 70's and those machines are incredible. Been meaning to get down to Eureka Samoa speedway for a while.
Reactions: John Cooper
I grew up at the Atlanta dragstrip before that was it's name. My mom worked there when they started building it. We still went every year till NHRA sold it off. 🤬
If you have not been since the 80's it has changed a ton. I didn't see TF from around 1990-2010 and the difference was huge.
These facts are simply mind blowing but they illustrate such impracticality that you can't help but keep reading.
took my girl out to Summit Raceway last year. we were right on the rail, and she flipped out when the 1st monster ran, she'd never seen 1 b4 and we'd been watchin funny cars for the last couple hrs, she was not prepared for the dragsters.
25-30ft away about 20ft off the line.....................your whole body shakes. we had to watch the rest from the stands.
they usually end the show with the jet Kenworth and that's an experience to be close to also.
One of these days, I gotta get down to Martin Speedway and watch the NHRA National event. Its gotta be on every gearhead's bucket list, regardless if you're into drag racing or not.
Summit can't be that far for you it's NE Ohio. and Norwalk Raceway is pretty active during the summer, they do lots of street racers and special events.
Martin has been on my bucket list also for a good number of years. Just need to make that happen.
We have the advantage of having the first and last race of the season in Pomona. Winternationals and Finals. We went to both every year for many years until it started interfering with wheeling season.
