Torquing procedures
MountaineerTom
Sumter, SC
When you're torquing a nut and bolt, and have the option to put the torque wrench on either the nut or the bolt, which do you do?
If possible, I always choose to use the torque wrench on the nut and hold the bolt with a wrench. I don't really know why I do it that way, I just do. I know there are times when you torque a bolt into a solid (or near solid object) and the opposite, a nut torqued onto a stud. Or even having access to put the torque wrench on one or the other.
Just curious how others do it.
voodooridr
North Idaho
That's how I've always done it, right or wrong
Reactions: MountaineerTom
JMT
Saxum Erepo 🪨
Whichever is the easiest access. It shouldn't make a difference in the end. If you swap the torque wrench to the other side it should still click confirming that the torque is the same from either side.
SSTJ
Inexperienced Overthinker
Lifetime Supporting Member
South Carolina
Same here. Not that I'm experienced enough for my habits to inform others.
